V nosed trailer with the slant
britishedx
First Name: Chris
Last Name: Tonwe
* REQUIRED* Type and Year of Model Ts owned: 1923 Ford Model T
Board Member Since: 2022
Post by britishedx » Tue Feb 14, 2023 5:54 pm
Has anyone here got a V nosed trailer with the slant. I have a 18 foot v nose and it pulls worse than my 34 foot toy hauler. I think it is due to the square edge at the top of the V. I have seen a few V trailers with the slant top and was wondering if that would pull better. INPUT???? Thanks
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Post by FreighTer Jim » Tue Feb 14, 2023 6:48 pm
Many factors go into how a trailer acts
while being towed down the road.
Regarding the V-Nose Design:
It does not reduce wind resistance
It reduces interior cargo space
It saves the manufacturer
material & labor on construction
A Coffin Front Design with a nose cone
will increase fuel economy for the
tow vehicle by 1 to 2 mpg and the
trailer will stay centered behind
the tow vehicle at reasonable
towing speeds.
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
Re: V nosed trailer with the slant
Post by Norman Kling » Tue Feb 14, 2023 9:15 pm
The way a trailer follows depends a lot on the distribution of the load and also the angle of the hitch. The hitch should be level or a bit lower than the rear of the trailer and the load should be just ahead of the wheels. Otherwise you will fishtail.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Tue Feb 14, 2023 9:29 pm
I would be looking at hitch angle,see if the brakes are sticking and so on,if you have no trouble pulling 34 foot,a 18 foot should be a walk in the park.
somethings not quite right.
Post by TXGOAT2 » Wed Feb 15, 2023 9:45 am
Tire types and tire pressures on the combination will have an effect. Condition and suitability of the tow vehicle is important. The type of trailer suspension can be a factor. A hard cover over a pickup bed or a camper shell might reduce aero drag of the combination.
