Way OT, but still older...93 Toyota Supra upgrade. Super Zoom Zoom !!
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Mar 11, 2020 1:55 pm
Maybe of interest to some of the muscle car guys.
93 Supra 3.0L I-6 twin turbo....320hp, 6spd manual RWD.
Customer is having me upgrade the whole car basically to a single larger turbo and in the end it will be putting 600hp at the wheels !! :shock:
Here’s a couple before pictures...Oh and after I get done it’s off to the body shop for a complete paint job.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: Way OT, but still older...93 Toyota Supra upgrade. Super Zoom Zoom !!
Post by Ruxstel24 » Wed Mar 11, 2020 2:04 pm
I started underneath a couple months ago and had to move it off the lift. Back on and been getting things accomplished.
Complete new exhaust system, old one off.
New clutch is necessary, so I did that first along with a seal leak at the shifter shaft...Thankfully the transmission was out, ended up having to split the rear case off to get the tiny little $9 seal out from the inside. :roll:
But the transmission is mated back up to the engine and just a few bolts and the driveshaft left. Got all the bottom exhaust manifold nuts loose while the transmission was out, since a new manifold is being used.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Wed Mar 11, 2020 3:44 pm
Crazy kids! You have been busy Dave. Its ok cause its black and does pay the bills. 600 hp! Hang on to your @$$ in that thing! Now get that T back together! :D
Hope you found the gear you were looking for?
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Mar 11, 2020 9:00 pm
Nope, no luck on a gear Dallas...still waiting for Joe. Saw some 11 tooth at Marietta, but I got plenty of those.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Mar 11, 2020 9:19 pm
Those are some hot inline sixes for sure!
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Wed Mar 11, 2020 10:11 pm
A friend does these in the Dallas area. It is all he does. Those Supras sent from all
over the world for him to build into drag monsters. It is an interesting process to watch.
Much different than my 60's stuff !
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Fri Mar 27, 2020 1:15 pm
Back at it again....not much going on around here. I’m open, but no one is putting money in their cars. So got the wife’s Subaru in and did some needed repairs and a few more things I found while on the lift. :roll:
My goal today is to get this conglomeration of a turbo/exhaust manifold off.
Piece by piece had to come off to get to the nuts. Piping and a shield and vacuum lines...etc.
Now I can see the upper nuts, all will needed heated up to get loose like the bottom ones did.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Fri Mar 27, 2020 5:49 pm
You have more patience than I. Plastic, rubber and aluminum. Seems every plastic clip I touch breaks and parts froze together with rust or corrosion. If you cant turn a 100 rear old nut that is 50% rusted away, I dont want to do it. :D
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sat Mar 28, 2020 12:38 pm
I got the old stuff off yesterday...quite a pile it made.
Did a mock fit on the new. All the studs have to be swapped with shorter ones. I just realized the kit has new fuel pumps and the tank has to come out to swap them. Good thing I haven’t got the driveshaft or exhaust in place yet. :P
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Apr 01, 2020 3:25 pm
Exhaust studs swapped and loose fit of the turbo and down pipe.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Apr 01, 2020 3:29 pm
Yesterday and today I got the upper intake manifold off....that was less than fun. :x
Old fuel rail and injectors off, new dual feed rail about ready to install.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Fri Apr 03, 2020 8:39 pm
Holy cats! There's a lot of stuff crammed in there!
And you didn't replace the alternator yet while it's half tore apart on that side? :lol:
Cool project Dave.
John Warren
Last Name: Warren
Post by John Warren » Sat Apr 04, 2020 10:46 am
I am looking forward to more coverage . I am concerned about an old engine with that much added stress. I turbocharged a stock Corvair engine in my sand rail many years ago. One of the problems was crank case pressure. I could't keep oil in it. I finally put two 3/4" breather hoses from the valve covers to the air filter cover. That did it! Holly suffering catfish did that thing run! It was an air research turbo off of an Oldsmobile, I blocked off the pressure relief system. Won many races with that set up. Thanks for posting. jw
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed May 06, 2020 11:08 am
This is kinda a fill in job, when I don’t have other people trying to get in for “normal” repairs...
Had a lot of big jobs come in and haven’t had time to get back into the Yota.
Located a correct pair of wire terminal crimping pliers. Got the fuel rail in place with new injectors. Different connectors at the injectors required new terminals and connectors.
New and old connectors shown in second pic.
Can anyone say tedious ?! :shock:
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Wed May 06, 2020 11:53 am
On old things I can say it Dave. Not so much on newer stuff. Thats gonna be a screamer !
