SHOW US YOUR LATHE
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
SHOW US YOUR LATHE
Post by BE_ZERO_BE » Fri Jul 03, 2020 2:24 pm
Many of us have a lathe to support our Model T and other projects.
Show us your lathe.
Mine is a PBR (Perico Baroni & Raimondi) made in Italy in 1966.
It's a 12 x 40 and can cut SAE & metric threads.
It replaced an Atlas 10 x 36 Pick-O-Matic lathe.
Respectfully Submitted,
Be_Zero_Be
MTFCA Number: 1219
Re: SHOW US YOUR LATHE
Post by Rich Eagle » Fri Jul 03, 2020 7:37 pm
It seems there are a lot of these Craftsmens around. It's made a lot of T and other stuff.
Sorry it isn't as clean as it should be.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Fri Jul 03, 2020 9:55 pm
Forget the lathe. Show us your neon, Bob !
Ken Buhler
First Name: Ken
Last Name: Buhler
MTFCA Number: 49471
Board Member Since: 2012
Post by Ken Buhler » Fri Jul 03, 2020 10:29 pm
I am blessed to have met a nice 93 year old man who decided to hang up his guns and lighten his load. He certainly did not use it much. This Atlas 12 - 36 is from about March 1981 at the end of production. He saved the original manual in mint condition, many South Bend 1938 Bulletin booklets, all the original attachments and acquired a lot of tools. This has changed my shop life in a wonderful way. I love this hobby and am grateful to meet so many of you.
Work honestly
Stay true to your word
Get the job done right
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Fri Jul 03, 2020 11:46 pm
Here you go Burger.
Be_Zero_Be
1923Touring
First Name: Joshua
Last Name: Hawkins
MTFCI Number: 24919
Post by 1923Touring » Sat Jul 04, 2020 12:56 am
This lathe has gotten me through small jobs, axle housings and flywheels.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sat Jul 04, 2020 1:59 am
These are gorgeous "studio shots" of lathes! Wow! :-)
Have a little chinaman behind me and a Woods Brothers angled-turret under the lean-one. Not good enough to be called lean-to.
A couple of not so pretty shots of the two SB lathes here.
465. Down the ways of a 12x6 (they used total bed length, not capacity way back then), #926 off the line,
sold June of 1911 to F. E. Satterlee , a Minneapolis based machinery dealer. Screaming along at perhaps 200 rpm's.
Making a missing rear bushing for a front axle reach (Front radius) for an old Twin City tractor.
Guessing on the dim's with surrounding info and research.
Where the ball would hook up to the pan on a T for that reference...
687. Nice little SB 9x36 from March of 1938, type C with a crummy chuck. It was GIVEN to me a few months ago. I waited for almost 5 years for this little buddy. I would've paid for it but no.
I actually stole the Standard/Blue Streak cupboard out of the dumpster on that trip. Stuffed in the little shop.
Very happy to have them all. Very handy.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Jul 04, 2020 3:43 pm
I started out with a 1958 built Wade 8A precision toolmakers lathe. While only 8” x 24” capacity, it was a very impressive small lathe. From the original literature it appears to have been a competitive brand to the Hardinge super precision bench lathes of the time. Features like variable spindle speed, prismatic bed ways, taper attachment, spindle speed tachometer, English/metric quick change gear box, and A-2 taper quick thread spindle nose all made the lathe real easy to use. I added an Aloris quick change tool post, and mounted some modified digital calipers to use as a DRO to improve repeatability and precision.
The options I didn’t have were the optional electric variable power feed, and the lever action collet closer. The spindle was factory machined to accept a W series collet (exactly the same as the 5c collet except slightly shorter OAL and used buttress thread profile). My plan was to convert the lathe to the much more available 5c collet, but never came across a closer... until after I gave the lathe to a friend that is...!😉. So he can do the work someday.
Don’t have a pic of the one I had... but this one is almost identical (thanks google)
BobD
First Name: Bob
Last Name: Doris
* REQUIRED* Type and Year of Model Ts owned: 1926 Runabout, 1930 Sport Coupe
MTFCA Number: 32538
Post by BobD » Sat Jul 04, 2020 8:29 pm
Enjoying the lathe pictures. :)
Kevin, that Wade 8A does have some similarities to the Hardinge tool room lathe I used at work.
Here is mine. Myford 254s self imported direct from England new in 1985. 10” swing, 20” between centers. Inch or metric thread cutting.
I have added a few upgrades, variable speed DC motor, tach, Aloris QC tool post, etc. It is surprisingly rigid for its size, accurate and a joy to use. Have 3 jaw, 4 jaw chucks and a 10” faceplate. Setup shown is an ER-25 collet holder for small diameter work.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Sat Jul 04, 2020 10:30 pm
Seeing Bob's Budweiser Ice Cream Neon sign reminds me that during prohibition Budweiser went into the Diesel Engine business. They provided industrial and marine engines for industry and ships. In fact Bob will remember the Washington State Ferry Kalakaua plying Puget Sound for many years. When it was finally scrapped it was noted the engine rocker cover and name plate stated it was a Budweiser manufactured motor. A little known fact lost in history.
frontyboy
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Sat Jul 04, 2020 11:40 pm
My South Bend 9", model A, from 1946. I've had it almost 25 years. Sure is handy!
HornsRus
First Name: Charley
Last Name: Shaver
* REQUIRED* Type and Year of Model Ts owned: 1913
Post by HornsRus » Sun Jul 05, 2020 11:34 am
i have to have 3,ha,ha. charley
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Sun Jul 05, 2020 12:49 pm
Rockford. It does what I need. Late 20's or early 30's.
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
MTFCA Number: 51354
Board Member Since: 2010
Post by flatbroke3 » Sun Jul 05, 2020 4:34 pm
well here is my toy, I only do watch work on it. 8 ft bed with 24 in swing.[image][/image]
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Sun Jul 05, 2020 5:04 pm
i.p.
Here is my other one. :D
MTFCA Number: 1219
Post by Rich Eagle » Mon Jul 06, 2020 11:01 am
Yes Dallas. How often we do have another one. :D
Walter Higgins
First Name: Walter
Last Name: Higgins
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
MTFCA Number: 396
MTFCI Number: 153
Post by Walter Higgins » Mon Jul 06, 2020 6:32 pm
My Monarch. Light as a butterfly. It is a baby as Series 60's go. 16" swing (catalog), 18.5" actual, 36" between centers, built in 1948. Despite its size it can still do very fine work on small pieces. Its only limitation for little things is that the spindle doesn't go over 700 rpm.
Dennis Prince
Last Name: Prince
MTFCA Number: 22802
Post by Dennis Prince » Tue Jul 07, 2020 5:23 pm
Mine is a old Atlas that came out of the Nasa shop at Moffett field a long time ago, I got it out of a retired from Nasa machinist that had it stored in his chicken shed, it even came with the original manuals.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Jul 07, 2020 7:04 pm
Here’s my current lathe...
2000 Milltronics CNC, 16” x 60” bed, 7.5 hp, 3000 rpm, 8 position turret, pneumatic 5c collet closer, and flood coolant. She’s got a few miles on ‘er, but still makes good parts every time I fire ‘er up.
Makes a great flat spot too...!😉
MTFCA Number: 52564
Post by Mark Gregush » Wed Jul 08, 2020 11:19 am
Atlas 9" long bed converted to 10". Not a quick change setup. The 3 jaw chuck is really out, but as long as I don't take what I am working on out, it works ok. Guess I will have to get some photos, don't have any on this computer.
1920 Dodge touring
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Jul 14, 2020 11:12 pm
How bout yur other machines???
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Wed Jul 15, 2020 8:00 am
Our 10" South Bend from 1943, probably came out of a WW2 mobile workshop truck, hence the lightweight under cabinet, it was in a sorry state when we got it but luckily all parts are still available so we refurbished it and it works just dandy for us !
Leo van Stirum, Netherlands
Kaiser
First Name: Leo
Post by Kaiser » Wed Jul 15, 2020 8:03 am
Yoohoo i got a picture to post right side up ! thats a first for me... :lol:
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Jul 15, 2020 2:34 pm
I’ve always liked the bent tube cabinets under those ‘ol South Bend lathes 👍
Kaiser
First Name: Leo
Post by Kaiser » Wed Jul 15, 2020 5:10 pm
Kevin the cabinet is quite sturdy but on the light side, a heavier cast lower makes a big difference in stability, but hey it was cheap and it came with all the right gears for turning SAE threads, which is not that common on lathes our side of the big pond. I didn't think twice when it came up for sale for just that reason
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Jul 16, 2020 9:35 pm
Not a lathe... but kind of a linear lathe...🤔
An ‘ol Ammco 7” shaper. Probably ‘50’s ish. Came to me from an estate sale... one of those “if you want this, you gotta take that” type deals. I was completely cleaned up, repainted, and mounted to a Craftsman table saw stand. I had no use for it, and couldn’t get rid of it... so I found a use for it! Made up a fixture to broach the axle keyway in the rear hubs I make for the Buffalo wire wheels. Been a good machine, but a 1/4” keyway in chromoly is about all it can handle
Walter Higgins
First Name: Walter
Last Name: Higgins
MTFCA Number: 396
MTFCI Number: 153
Post by Walter Higgins » Mon Jul 20, 2020 10:39 am
K&T 2HL Swivel Head. The lightest vertical mill that K&T made at about 3,500 lbs. Has a 40 NMTB spindle with the high speed option up to 2,400 rpm.
Always interested in anything Kearney and Trecker -- from machine accessories to collectibles.
Toddman
First Name: Todd
Last Name: Manoff
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout, 1923 Speedster
Post by Toddman » Wed Jul 29, 2020 2:41 am
Here’s my ‘ol Prentice Bros. 16 lathe. Has brass drip oilers and was originally designed to run off a overhead flat belt system. Has the big wide belt pulley on the drive end. Dated 1888 &1896. I fitted a smaller chuck as the originals that came with it are huge beasts. When i bought it, i welded up a framework so it would be on casters. The seller loaded it up on my trailer with his fork lift. When i got home i laid out a plywood pathway and was trying to figure out how i was going to roll this thing off my trailer, up a curb, over 10 ft of plywood covered dirt, up onto some not so level concrete and then down a couple inches into my shop all by myself. Just then a moving truck from heaven pulled up with two monstrous men, “Do you need a hand with that?” In less that 5 minutes my old lathe was in my shop. I’ll never forget those generous souls, they were life savers!
Walter Higgins
First Name: Walter
Last Name: Higgins
MTFCA Number: 396
MTFCI Number: 153
Post by Walter Higgins » Sat Aug 01, 2020 4:04 pm
A bump just to keep the thread alive. Marvel No. 2 power hacksaw salvaged from a factory several years after it flooded. Not as efficient as a horizontal bandsaw but takes up a lot less space and sure beats doing it by hand.
MTFCA Number: 1219
Post by Rich Eagle » Sat Aug 01, 2020 8:35 pm
I remember one like that at work years ago.
I found this brake drum lathe at a swap meet a few years ago. I thought I might adapt it for spinning brass as that is hard on my real lathe. As it turns out it is perfect just the way it is for rotating hubs, drums and all sorts of round things to clean. I just hold sand paper or wire brush etc against the spinning object and let the machine do the work. Water and solvent can be used in small amounts but too much can fly 360 degrees and make a mess.
I didn't pay much. As soon as I bought it another fellow was very disappointed that he missed out on it. It had some special motor he wanted. Since he didn't want the machine I let him have the motor for what I paid. I found a cheap motor that works fine for it.
Billy Vrana
First Name: Billy
Last Name: Vrana
* REQUIRED* Type and Year of Model Ts owned: '25 homemade pickup, Fond Du Lac conversion tractor
MTFCA Number: 49514
Post by Billy Vrana » Sun Aug 02, 2020 12:41 am
A 16 inch Pratt & Whitney. I got it from a family friends estate, they had scrappers coming the next day.
So there I sit pulling some favors in a snowstorm
I like the hyroglifics for speed adjustments
And to think what went across the ways since 1903
Bill Dizer
First Name: Bill
Last Name: Dizer
MTFCA Number: 28610
Post by Bill Dizer » Sun Aug 02, 2020 6:06 pm
Leo, I have the mate to your 10"X 24 South Bend lathe. It is called a tool room lathe according to South Bend when I called for parts. Mine has a tag rivited on the front saying it " meets the standards of the war production act"! My stand is the same as yours and is very solid! Lots of parts on US eBay. I make a lot of parts for antique bicycles on mine.
Kaiser
First Name: Leo
Post by Kaiser » Wed Aug 12, 2020 4:52 pm
Bill the little South Bend is a great asset to our workshop, it could do with a scraping of the bed and the gears are a bit noisy at higher revs but we use it for the quick fixes and small jobs, we're sure happy to have it !
Some great behemoths here on this thread !
LVRR2095
First Name: Keith
Last Name: Taylor
MTFCA Number: 10631
Post by LVRR2095 » Wed Aug 12, 2020 5:18 pm
Not so good for Model T work.....but my little Derbyshire Model A is great for small work.
Keith
Derbyshire
Derbyshire
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Thu Sep 03, 2020 11:48 am
Had a little job for my buddy on the Rockford. Had some party animals in the shop I guess?
Stopped the feed dead.
modernbeat
First Name: Jason
Last Name: McDaniel
* REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
MTFCA Number: 50306
Post by modernbeat » Thu Sep 03, 2020 12:34 pm
The lathe is the box on the left. The other robot in a box is the mill.
Jason McDaniel
modernbeat
First Name: Jason
Last Name: McDaniel
MTFCA Number: 50306
Post by modernbeat » Thu Sep 03, 2020 12:37 pm
The "other" lathe in the home garage is a manual Craftsman.
In this photo I'm making a run of 60 adapters for some vintage office lighting.
Jason McDaniel
modernbeat
First Name: Jason
Last Name: McDaniel
MTFCA Number: 50306
Post by modernbeat » Thu Sep 03, 2020 12:38 pm
And there's a mill too. Making some bracket to hold a clutch cable for the old 1963 SAAB rally car we used to run.
Jason McDaniel
LVRR2095
First Name: Keith
Last Name: Taylor
MTFCA Number: 10631
Post by LVRR2095 » Thu Sep 03, 2020 12:45 pm
Sanford surface grinder
Just got this little Sanford SG surface grinder going.
It had been in storage for twenty plus years.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Thu Sep 03, 2020 2:08 pm
My lathe is a drill press and a file.
My mill is a vise and a file. :)
AdminJeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
MTFCA Number: 50006
Post by AdminJeff » Wed Sep 23, 2020 11:48 pm
1943 Southbend 9" model A off of a Navy ship according to Southbend. Got it in 2018 for $400, and completely rebuilt it. I don't know how I lived without it for so long...I mostly use it for rebuilding starters and generators, but I'm constantly finding new uses for it.
Assistant WebSite Admin
Voltage Regulators, Starter & Generator Repair
www.modeltregulators.com
www.modeltstarters.com
