1928 SPRINT CAR
Topic author - Posts: 306
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
Re: 1928 SPRINT CAR
My wife posted these pictures in the wrong place they were supposed to be in the "non Ford what did you do this month postings, sorry
frontyboy
frontyboy
- First Name: dick
- Last Name: dock
Re: 1928 SPRINT CAR
For some reason my post under non Ford projects has disappeared. So this sprint car is what I have been working on for over 8 years. Now I'm not that fussy, just lots of interruptions. Target date for finish is August 1st for a Speedster run to Mt Baker.
All thats left are graphics, installing the seat and brake and steering adjustments and it DONE. There actually is light at the end of the tunnel.
This sprint car is a restoration of an original sprinter from the 30's. 1928 Chevrolet 4 port motor and transmission, Overland narrowed frame, front and rear end, Budd wire wheels, Winfield Down draft carburetor, and vertical 4 cylinder magneto ignition. It runs and drives well, loud fast and exciting to wheel down the road. Now is almost done, my single stick Fronty speedster is next. It will not take 8 years as I don't think I have that many years left to do the work.
frontyboy
frontyboy
- MTFCA Number: 52564
Re: 1928 SPRINT CAR
Cool! Did you mean 3 port Olds head or stock 2 port?
1920 Dodge touring
1920 Dodge touring
- First Name: dick
- Last Name: dock
Re: 1928 SPRINT CAR
Stock 2 port in and out, with aluminum intake with Winfield down draft and short tuned exhaust stacks, add a grind on the cam and magneto ignition it is loud, snarly, quick and one hell of a lot of fun to rip up and down the road.
I have a 3 port head but the general thought is that the 2 port is much more efficient. The Olds 3 port does not have the straight through easy breathing that the Chev 2 port does. Guys that have used the 3 port have not seen any improvement so I have the 3 port on the shelf.
frontyboy
frontyboy
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
Re: 1928 SPRINT CAR
Dick, there are too many questions I'd like to ask about that 1928 Chevrolet engine.
If I'm given enough years, I need to put together a straight-eight with 2, 1928 4's. I've 3 or 4 candidates here.
Just lots of interruptions here too and many road blocks 30 years ago.
How's the crankshaft? Mine are bent and quite difficult to bend back. I need to dare learn the old time technique of peening the shaft back to near straight before regrinding. Tough cookies, those shafts are. My first peen trial is a bent, almost 3 foot long cam shaft.
Would you show us a photo of the engine?
HOT looking sprinter! Thank you!
Re: 1928 SPRINT CAR
Thanks for the info on the 3 port, good to know. For my type of use with the Chevrolet conversion, I have considered going to smaller intake valves. Mine is going for the wow not race factor. If you look at the runners for the intakes, they are pretty big anyway. I think you could drive a Smart car in there and get lost! LOL Did you leave the baffle things in the openings? I may have made a mistake by removing them for my usage.
Everything you wanted to know about the 28 Chevrolet engine and then some! LOL :
https://www.jalopyjournal.com/forum/thr ... or.463465/
https://vccachat.org/ubbthreads.php/top ... 335/1.html
http://chevy.oldcarmanualproject.com/ch ... 8index.htm
These will have you reading for some time.
1920 Dodge touring
1920 Dodge touring
- First Name: dick
- Last Name: dock
Re: 1928 SPRINT CAR
I removed those diffusors from the intake ports. My thought was when Chevrolet put those in their engines, the gas quality was very poor and they were trying to get it enter the ports more mixed with intake air. Not an engineer but it makes sense to me. When we cc'd the ports and combustion chambers, they were amazing equal which for a old production motor was quite unusual, a tribute to the Chevrolet's racing background.
What I do know is that with the upgrades I have made, a Winfield and Aluminum intake there is no lag on accel, either light or flat to the floor pedal pressure. This engine flat spins up really fast. I did not polish the ports or try to enlarge the valves. When you look at the head and the pass through ports, I did not think I could improve it. Also consider the Louis Chevrolet designed engine, I did not think I could improve his design or engineering. I also did not know how much material was available to remove without getting into water chambers. While I have not weighed this car, my guess is it is about 1200 pounds give or take, so with an easy breathing 4 cylinder motor and light weight, it is probably way to fast for an old fool such as myself to drive really fast.
My new car, Fronty single stick engine has a scat stroker pressure crank and their insert rods bearings, Aris Hi Compression pistons, full pressure oil. This engine is built for speed as the rest of the car will be too. Still under construction and hoping for next summer finish. Now I just need some one with big enough kahunas to drive it, at soon to be 77 years old, I will not be pushing the limits, those days are over.
Any other questions, just ask and I will try to answer.
frontyboy
frontyboy
- First Name: Kim
- Last Name: Wynn
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
Re: 1928 SPRINT CAR
I'm your huckleberry. If you need a guinea pig call me! I'll try anything once. I'm an old hillbilly with the credo "hold my beer and watch this". HA!
- First Name: dick
- Last Name: dock
Re: 1928 SPRINT CAR
Your #2 on the drivers list!!!
I drove my last single stick Fronty sprint car 75mph, I was a lot younger and far quicker reaction time. The fastest I have ever driven was 140mph in my Ferrari 348 spider in eastern Washington. Long straight roads noo traffic 'cept a John Deere or 2. As I said those days a long past. Today I'm hard pressed to get over 60mph.
frontyboy
frontyboy
