Here's a Switch. ('35 starter Sw)
MTFCA Number: 1219
Post by Rich Eagle » Sat Aug 15, 2020 7:03 pm
While I was waiting for parts for my '35 I took apart the starter switch. It's a little like a T switch. It was frozen from lots of rust inside. It is held together buy bending 4 tabs at the corners.
The contact bar is held to the plunger by riveting it over a washer. It had to be drilled to get it apart. I made a piece to replace the ruined pin and pressed it into a hole I bored in the plunger.
The spring was rusted, broken and had little spring left in it. I stretched an extension spring and made it a compression spring. The insulating pieces were a cardboard which had decomposed. I had some hard rubber to cut and replace it.
The copper pieces cleaned up well.
MTFCA Number: 1219
Re: Here's a Switch. ('35 starter Sw)
Post by Rich Eagle » Sat Aug 15, 2020 7:07 pm
I annealed the 4 tabs before bending them back in place. Then painted it with some silver Rust-Oleum. Then I sun baked it outside at 88°.
A new switch is $24.95 to $ 27.99. They look like good reproductions. I spent 4 days rebuilding this one. It was a very satisfying project and seems to work well.
Worth it to me. Perhaps not for others.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sun Aug 16, 2020 1:35 am
Ick. Hot. Oh, but it's a dry heat...
Fiddlesticks.
In the yard, playing with OT, 81, 57 degree dew-point and sunny. Was blinking hot.
Aww poop, now you have me wanting (more) to work on the '45 Flat Head amidst all my other pressing projects.
Just pressed the button on the '45 and away it went. 25 years ago...
Thanks Rich!
Angmar
Last Name: Bailey
MTFCA Number: 50335
Post by Angmar » Tue Aug 18, 2020 10:00 am
Nice work Duey.
Still crankin old iron
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Aug 18, 2020 9:45 pm
Satisfaction Rich in bringing it back from the brink of scrap seems to work for you. I love to see your projects from paint to rust. Show me more.
Dallas
