Stick handle for a lincwelder ac-225-s?
Topic author - Posts: 913
- First Name: Ignacio
- Last Name: Valdes
- MTFCA Number: 50406
Hey, I found a lincwelder ac-225-s on the curb. See the picture for the stick holder that is missing the top part. Can the top part be purchased or do I have to replace the whole stick holder handle?
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Stick handle for a lincwelder ac-225-s?
Should be able to purchase entire stick holder at your local farm store pretty cheap. Good score.
- Last Name: Valdes
Are these standard? I've never owned a stick welder before. Also the clamp is missing is that generic as well?
- First Name: Jack
- Last Name: Murray
- * REQUIRED* Type and Year of Model Ts owned: 1926 light express
- MTFCI Number: 24449
Are you sure this is part of a stick holder? It looks like the male half of a cable connector, used for coupling additional lengths of welding cable...try putting 'TWECO cable connector' in a Google search and I think you'll see what you've got there. Regards, Jack
- Last Name: Valdes
It could be. I've never had one of these before. So I can get a female adaptor and add an additional length of cable then I hope. Is it 2 gauge or 4 gauge wire that these usually use?
yukonjack wrote: ↑Wed Oct 28, 2020 8:47 pmAre you sure this is part of a stick holder? It looks like the male half of a cable connector, used for coupling additional lengths of welding cable...try putting 'TWECO cable connector' in a Google search and I think you'll see what you've got there. Regards, Jack
- Last Name: Valdes
I looked at the fine print and sure enough it is a Tweco cable connector!
ivaldes1 wrote: ↑Wed Oct 28, 2020 9:40 pmIt could be. I've never had one of these before. So I can get a female adaptor and add an additional length of cable then I hope. Is it 2 gauge or 4 gauge wire that these usually use?
- First Name: Mack
- Last Name: Cole
- MTFCA Number: 28146
cables look to be cracked a bit.Wrap with tape .
Those are tough machines.Shouldn't be much if anything wrong with it other than missing the leads.That is a Tweco quick connect,should be able to get the other end of that pair at any decent welding supply store.Ground clamps,Harbor freights work fine.Should even be able to get the stick holder there as well. Cables are the most exspensive part.
Show the whole machine and maby we can tell more about what is missing.
- Last Name: Valdes
See the picture. It is heavy. The rheostat dial is stuck so I am probably going to have to take it apart and figure out why. I have some wide and long enough heat shrink wrap that I was going to cover the cable cracks with. Harbor Freight is a good idea I will try them.
tdump wrote: ↑Thu Oct 29, 2020 9:25 pmcables look to be cracked a bit.Wrap with tape .
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
I don't recall seeing a quick release on the rod holder on those Lincoln's, just direct connection. So maybe don't be looking for something to fit what is there or check eBay.
1920 Dodge touring
1920 Dodge touring
- Last Name: Valdes
It may have been retrofitted with the Tweco. The cables are relatively short.
- Last Name: Valdes
I got back to seeing if I can get it working again. I opened it up, it had rats nests and crud. I blew out all the crud with a leaf blower and wire brushed the rest of the rodent mess out. I tried plugging it in with the covers opened, something went fritz smelled a little burnt now it won't do anything but I have no idea if it was working at all before. I was able to free up the welding power dial switch. No fan, nothing. For what it is worth here are some pictures of the insides. What should I do? Are these worth repairing?
- Last Name: Valdes
Replaced the rotted cable, obtained a clamp and a handle and it works!!! Love curb finds!
Glad to hear you finally got it going. Good things come to those who are willing to wait.
