Capacitors to replace condensors: T's and other things.
Topic author - Posts: 1518
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
Back story. I can't recall the values but we regularly replace the condensers with capacitors in our model T coils. Old news.
I have orange drop capacitors for my Twin City tractor magnetos that we also regularly replace the aging condensers. Old news.
American Bosch ZR-4's, U-4's and would be perfect for DU-4's also. Funny, some replacement mags for the T's.
Maybe even good for E-4 or F-4 IH magnetos. Don't recall the values there either.
More back story. I have a late 90's TTP dizzy on the 24 Crappy model T. The original Bosch condenser lasted a LONG time.
The replacement condenser I'm not betting on. A couple years ago already, It refused to start.
My oldest VERY reliable crank starting Model T.
Yes I know but did not even have access to a box and coils back then so it got a dizzy. $320 Dollars back then! Oww!
Question: Anyone out here have a guess about values for a replacement capacitor for (let's say) a Bosch JFU4 DISTRIBUTOR for an early 80's Gehl skid loader with a 98 cu in Ford Industrial engine (Pinto) OR EVEN a T powered Texas T Parts distributer?
Very similar distributors.
Even more back story. I had wondered about replacing the Gehl's new Bosch (Turkey) condenser with a capacitor the last couple years but bit the bullet and bought a new US made distributer from a company out east. $$$$
Ugh. Pertronix Ignitor II.
Runs better already. AND about the LAST time I work in the back door of that consarned loader.
Can't even see where the distributor goes into...
I'm tiring of modern condensers. Like others are.
Any help much appreciated. Thanks!
- MTFCA Number: 24868
Re: Capacitors to replace condensors: T's and other things.
Condensers and capacitors are the same thing, aren't they???
- First Name: Duane
- Last Name: Cooley
You know they aren't.
Shoot. You got me there...
They really are the same...
You know full-well what I was getting at.
I'm looking for values for an orange drop capacitor to be used in a four cylinder distributer like a Bosch that might be on a T.
Thank you at least for responding.
I really wasn't trying to be a smart aleck. As to your question, I really don't believe an orange drop style condenser/capacitor/thingy is correct to use on a distributor.Duey_C wrote: ↑Sat Jan 30, 2021 12:37 amYou know they aren't.
Here is what I would use. If it doesn't fit inside the distributor body then just hang it on the outside.
https://www.ebay.com/itm/A-C-Condenser- ... SwSw1eQz75
- First Name: Duane
- Last Name: Cooley
I know you weren't being a smart aleck. No worries there.
But you make me think. That's a good thing. Thank you.
Both of these Bosch dizzys already carry the condenser outside so that wouldn't be much of an issue.
Nobody stamps values on condensers anymore and parts men cannot say what they are either. Also part of the hang-up.
The ten hour run time with genuine parts before needing replacement is what's getting to me.
Always trying to think outside the box also.
Have a 70's Bolens large-frame tractor with the 20 horse Kohler twin. Those NAPA or Kohler condensers weren't any good either so I bought a condenser for a '73 Chevy 350. Works fine now thankfully. I asked Barry (he's a parts book man) what the values were. He didn't know.
Turned an IH F-6 magneto into a 12 volt remote automotive coil due to a bad original internal coil many years ago.
And the American Bosch mags here now with capacitors of course.
Longevity is the aim with the dizzys.
OK. I'm going to ask: Why wouldn't a capacitor be correct for a distributor? Not needling/poking at you. Curious.
Edited. One word for correct grammar. Du
- MTFCA Number: 52564
Don't know why you couldn't use a capacitor. The single lead auto condenser is grounded thru the case (re grounded, pretty sure on that) with the lead going to the points. Some Dodge's use a condenser that has two leads, one end going to the points the other to ground, which should be like the capacitor with two leads. Wouldn't they both do the same job?
1920 Dodge touring
1920 Dodge touring
Duey,
I'll admit that my reasoning is pretty weak. It's because I've never seen it done. The thought being, that if that were the best way to do it, you'd see it done often. Certainly no harm in trying it out. Maybe start with the orange drop style & rating recommended for T buzz coils? Wish we could get some EE's to chime in here...
Check this out. Especially the second to last paragraph...
https://mgaguru.com/mgtech/ignition/ig129.htm
Here's some more chatter...
https://www.smokstak.com/forum/threads/ ... on.143172/
But wait, there's more!!!
https://forum.studebakerdriversclub.com ... -condenser
And... as to "orange drops" this was taken from an AACA forum posting, "You should be able to substitute a modern .22uF, 600V or higher voltage rating film or poly capacitor (orange drop). They are non-polarized. I have used this method to re-stuff an original condenser when appearance/originality is important."
(So, what do I know.... )
- First Name: Duane
- Last Name: Cooley
I’d like to see one of those two-lead Dodge condensers someday Mark. Interesting!
Aha! That’s the info that’s been eluding me Jerry.
MGA guru Barney’s write-up is easy to read and echoes my growing sentiment and findings.
I’ve read something similar a long time ago.
The Studebaker club’s thread is fantastic and there’s more info right there on the stak!
Many thousand thanks Sir!
Did some more digging today, three T suppliers won’t tell the uF value of the cap (capacitor) in the T coil.
In ‘09 Glen Chafin mentions in Toon’s thread that they “....use the 0.47uF, 400V polypropylene capacitor with a dV/dt rating of 6000.”
http://www.mtfca.com/discus/messages/80 ... 1248132830
Glen also had easy to understand info about the T coil condenser. Been there done that (adding a condenser to the outside of a model T coil) for a 1920 Fairbanks Morse engine that's putted away for many years that way.
Nasty old T coil. Zapped son a couple years ago. Hehehe!
This gets deep if ya look into caps... I merely dabble...
Yes. I type too much. Sometimes to my own embarrassment.
OK. Simply put.
A rebuilt model T coil nowadays has a modern .47uF orange drop capacitor. I have four here from Andy.
Most of the automotive world deals with about .22uF to .29uF capacitors. Good old condensers.
Air cooled engines like Onan’s seem to like .3uF (.30uF?) cap/condenser.
(Similar coils to the older Kohler twins with the “waste spark” method. Anyone understanding that statement chime in here.)
American Bosch ZR-4, U-4 and DU-4 magnetos also use the .22uF caps as replacements.
Dare I say this translates to the easier to relate to 47, 22-29 and 30 MicroFarads?
Named after Michael Faraday.
Corrections always appreciated! And on my nomenclature/grammer.
I have a couple 0.22uF 400V orange drop (Vishay) Sprague 225P’s left over and I’ll need more from West Florida Components if they also work in the IH F-4 magnetos here. F-4‘s are different birds.
I have a small job set for me this spring/summer! Armed with this “new” information, put an orange drop on my ‘24 Crappy Runabout’s Bosch dizzy to find the ins & outs of doing it.
My future sees a .22uF orange drop cap, some small heat shrink tubing, a couple crimp/solder-on electrical fittings, a soldered-on extension wire and a bit of luck.
The AACA fellow about re-stuffing a capacitor in a something... He’s right, can be done.
Last winter pics from my cozy little shop. American Bosch ZR-4. The U-4 and DU-4 are very similar.
1. 6164. Old condenser. See the wax around the old paper condenser? It smells horrible. Opened the door and used the fan in the middle of winter. Yuck. But it’s gotta go for the orange drop cap install. Don't inhale that wax smell.
2. 7123. Orange drop ready to be “potted” in. I used Ultra Black to hold it in the body.
3. 2595. Ready to solder the brass top back on the body. Note the threads in the nipple. They’re about done.
4. 2136. See the condenser body under the armature’s end plate. That pic is the armature coming apart.
OK. Simply put.
I don't know if any of the 3 or 4 Dodge distributors in my "collection" have the the type with 2 leads installed, I would need to go look. Here is one on eBay;
https://www.ebay.com/itm/NOS-1918-1928- ... 3731397323
1920 Dodge touring
1920 Dodge touring
I would probably go with 600V instead of 400V. Maybe a bit more robust.
- First Name: Duane
- Last Name: Cooley
That Northeast type condenser is crazy-cool Mark! I grabbed an image for the few interested.
Even a tour of my shop would show condensers/capacitors came in all shapes back then.
Makes me wonder what I did for that on a paper-wound (steel based and hat) coil for the Globelight engine & 32 Volt generator.
But it worked!
I'm crossing my fingers Jerry. With that said, I saved a Vishay Sprague .pdf and they do have 225P caps in the 600V range.
Back to study! Perhaps between my source and the original info source, there may have been a minor detail gone astray.
Or I simply made a dumb mistake...
Thank you!
But it worked!
Thank you!
I went thru my "collection" could not find one with it installed, I did have one loose. Did not look in the Dodge to see if it has one installed, didn't want to unwrap it today! The weather should be better tomorrow and will take a look see, need to run it anyway.
1920 Dodge touring
1920 Dodge touring
- First Name: Duane
- Last Name: Cooley
I sent West Coast Components an email and it turns out they do NOT have a Vishay-Sprague 600 Volt version of these 0.22uF Orange Drop caps I'm looking for.
For the time being, I'll stick with the 400 Volt version.
Thanks guys!
Thanks guys!
- MTFCA Number: 51486
I think the correct value (capacitance) of a capacitor/condenser in an ignition system is determined by the coil's characteristics. A value anywhere near correct will work, but the closer to the proper value, the longer the points will last.
- First Name: dale
- Last Name: dorando
- * REQUIRED* Type and Year of Model Ts owned: 1922 Model TT stakebed
I have 4 working coils and they all have 3000 to 4000 nF (3 to 4 uF) capacitors. They appear to be original, unopened, with the Ford logo. One has a small Ford logo with a big letter C under it. The capacitors look like the originals (glass insulator, 2 wood blocks and tarred).
I hate to open them and put 0.47uF instead since they work.
Comments?
I'd use them, and carry a spare working coil just in case. They might work for years, or not.
- First Name: Duane
- Last Name: Cooley
Back to this and a step in the right direction for me and those that don’t trust modern condensers.
Hope this might help someone else someday.
Let me know if I have the subject halfway straight or still all fouled up please.
Somewhere along the line, not here, I was chastised about Farad ratings.
A fellow claimed I was using .22 ultraFarad capacitors which are 100 times from what I needed.
I find no mention of an ultraFarad capacitor after some searching. I did find an error of my own also.
Nice to see interest on this subject! Happy
I found a gentleman in Texas that puts together capacitors/condenser replacements for very early 30‘s Chevrolet sixes.
They’d hide inside the distributer unless mounted outside.
I’ve since done business with him and he’s a straight, old-school shooter.
Got two capacitors meant to go inside a Chevrolet 216 or 235 six distributer.
Similar cap values. One for the M-M UTS tractor and one for the TTP Bosch dizzy’d ‘24 T.
See these if you wish: Caution, it is VCCA/Chevrolet’s for the faint-hearted soul...
https://vccachat.org/ubbthreads.php/top ... ensor.html
https://vccachat.org/ubbthreads.php/ubb ... er/451896/
https://www.stovebolt.com/ubbthreads/ub ... er/1388813
https://www.stovebolt.com/ubbthreads/ub ... 815/2.html
If mounted outside the dizzy, add to the wire.
No affiliation other than doing business.
Trials to come next year.
The .22 uF/microFarad/MFD for example. The uF is the symbol for the microfarad.
MFD is an alternate symbol that some folks use.
mF was already taken by the millifarad. MMfd is that alternate.
.22-.29 uF/microFarad/MFD should be in the range for most automotive, ag and magnetos.
.47 uF for the T. “....use the 0.47uF, 400V polypropylene capacitor with a dV/dt rating of 6000.” Glen C.
A .47uF microFarad/MFD cap is what he was talking about.
This table simply grabbed from the net but a help to me. The math is beyond me tho.
Shoot, I needed to convert it to a .pdf. Should be a clean conversion.
Darn it, I can't see it here on the site. Curses, foiled again. EDIT: .PDF didn't work so we'll try a screenshot. Bingo!
Condenser-1. Pat said it perfectly about matching the points and coil. ^^^
When I put the new distributer (Pertronix II) in the skid loader, it was suggested to buy the matching coil.
I did.$$ Funny, it appears just an automotive coil.
Condenser-2. Simple assembly. If one soldered a longer wire on, it should work just fine hanging outside the Bosch dizzy and was a suggestion by Jon the builder to lengthen the wire.
