Stewart Warner Vehicle Radios
Topic author - Posts: 233
- First Name: Paul
- Last Name: Grohsmeyer
- MTFCA Number: 27359
Anyone an antique radio expert ?
Trying to find some information on this Ford/Stewart Warner, but haven’t been able to determine the model or any identifying number.
The remote is mounted to the steering column, and the radio unit is floor mounted.
There are no identifying numbers on or in either, and not (currently) operational.
Any leads would be appreciated.
- First Name: BOB
- Last Name: CASCISA
- MTFCA Number: 16897
- MTFCI Number: 16628
Re: Stewart Warner Vehicle Radios
Most likely there is information inside the main radio.
Take the cover off and look inside.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- First Name: Paul
Been there - nothing.
- First Name: Dennis
- Last Name: Seth
BOB! ... If he takes the cover off all the music will spill out!
- Last Name: Seth
Well there you go.. see all the music is out and the box is full of other junk! get rid of that junk and dump some music back in and put the lid on it!
- First Name: Paul
Ok, I’ll just hide an 8track inside !
- First Name: BOB
Found it ... I Think
It looks like one of these
Be_Zero_Be
Be_Zero_Be
- First Name: Paul
Ok, I hope you’re right. But what leads you to it being one of those model #’s ?BE_ZERO_BE wrote: ↑Mon Feb 08, 2021 8:06 pmFound it ... I Think
Stewart-Warner.pdf
Thx
- First Name: BOB
The references to remote control.
Tube locations.
Vibrator power supplies.
The next step would be to compare the tube numbers and locations in your radio to the schematics.
I searched 7 volumes of Riders schematics to find these.
Tube locations.
Be_Zero_Be
Be_Zero_Be
- First Name: Paul
Ok, I will take a closer look. Thx.BE_ZERO_BE wrote: ↑Mon Feb 08, 2021 9:19 pm
[/size]
- First Name: BOB
Further research reveals this is a 1935 - 1936 (approximately) radio.
Be_Zero_Be
Be_Zero_Be
- First Name: Paul
Bob, I believe you are correct !
I got a cleaner copy of your doc, and the tube layout matches that 1171/1172 layout. The top left tube is not marked with anything but F7 on the base, but someone had marked the frame as a 78, and it appears to be identical to the other 78
(Much clearer as an original)
Now to find someone to see if it is operational.
I do not have the cables between the radio and the remote.
Thanks for your lead. ( I guess the 8 track will have to wait til later )
- First Name: BOB
Paul,
Glad I could help.
Finding the interconnecting cables will be difficult.
They are mechanical parts of the radio and do not show up on the electrical data.
Try an automobile radio repair shop.
I think one could be found in Hemmings.
Maybe they would have parts from other similar radios that might work.
Those cables are similar to a speedometer cable.
You might be able to fabricate something that would work just fine.
Glad I could help.
Be_Zero_Be
Be_Zero_Be
- First Name: Paul
Bob- Anything on that schematic lead you to believe positive or negative ground ?
- First Name: BOB
I don't have any first hand experience with this radio.
Based on what I see in the schematic, there is nothing polarity conscious in the power input unless the vibrator is.
Were 1936-37 Fords positive or negative ground?
That would be my first choice for connecting the radio to power.
Be_Zero_Be
Be_Zero_Be
- First Name: Paul
I believe most, if not all vehicles in that era were positive ground, and was my intent. Just don’t want to let the smoke out of anything, if I try to power it up. It is out of the vehicle so there won’t be any issue with the vehicle power.
And I don’t see anything internally that indicates anything has been burnt previously.
Thx.
Thx.
- First Name: Paul
Powered it up on 6v positive ground. All tubes lit, but a bit of a hum.
No smoke, so at least it not dead.
Looking for a local radio shop to get it tuned.
- First Name: BOB
Consider having all of the capacitors (condensers) replaced.
Most likely it won't work well (if at all) until that is done.
That is pretty much standard procedure in radio restoration.
Be_Zero_Be
Be_Zero_Be
- MTFCA Number: 51486
If your SW radio for a late '30s Ford or Dodge/Plymouth/Chrysler, it's 6V positive ground. The hum coming from the radio itself is probably the vibrator. They usually don't work if they've been sitting for years, but when they do work, they normally vibrate and make a low humming or buzzing sound. They perform a similar function to the vibrator points on a T coil, being used in conjunction with transformers and the rectifier tube to provide a higher, filtered DC voltage (over 100 volts) for the vacuum tube plate circuit. If the radio speaker gives out a low volume hum, that is also normal. The radio will probably have several large value filter capacitors (condensers) which are prone to decay over time. They may be OK, but they are suspect. A bad one can cause a very loud howl or buzz at the speaker. The smaller capacitors are usually OK. There are a number of antique radio specialists around the country who may be able to help with tubes, vibrators, capacitor replacements,advice, or service, etc. Early car radios can draw quite a bit of power compared to "modern" electronics. When the radio is first turned on, it will need several seconds to warm up before it will operate. Old radios, especially car radios, usually had very good receiving capability. Sound quality on pre-WW2 units may not be so great. Pre-1970 car audio equipment is getting hard to find. I'd handle that thing with great care! Keeping RF interference from the car's generator and ignition system out of the radio can be challenge, but it's do-able. I would NOT gut that radio and put newer electronics inside it. If you want high fidelity music, get a modern set-up with SXM and you can ride along in your T listening to 1940's music, or whatever, without interference from your car's electrical equipment. You can get great sound quality at high volume and almost infinite programming choices from modern equipment that takes up very little space and could be installed without altering the car.
///// It looks like a modern audio set-up can be used to play a variety of actual period programming.... ///// Radio Programs : Free Audio : Free Download, Borrow and ...
https://archive.org/details/radioprograms
Old Time Radio Programs, News , Winston Churchill News and Speeches. Alot of these are here in the WW2 collections, I posted this collection to make The Winston Churchill Speeches in one place. Topics: Old Time Radio, WW2, Winston Churchill .... ///// A number of sites offer old radio programming for Mp3 or free download... Will Rogers? FDR Fireside Chats?
- First Name: Paul
PatTXGOAT2 wrote: ↑Sun Mar 14, 2021 11:00 am///// It looks like a modern audio set-up can be used to play a variety of actual period programming.... ///// Radio Programs : Free Audio : Free Download, Borrow and ...
I did find that radioprograms site earlier when searching.
I will not be gutting this radio- it’s too complete of a unit, and in great shape. Just having trouble finding someone to tune it up. Lots of sites claim they do, but get no response when asking if they will.
Not that it would get much use, especially when driving, but would be neat to have it operational at shows controlled with the remote tuning pod.
Thx
It's very clean and complete. Remarkabley so. It looks as if some capacitors may already have been replaced at some point. It was probably long ago, and they likely need replaced again. You aren't likely to find any to physically match the originals, but functional equivalents should be available, and they will probably be a lot smaller than the originals. The resistors in that set date it to before WW2. They have the "BED" color coding (Body, end, dot). I don't remember how to read it, but information ought to be available. If the speaker is deteriorated, it can be re-coned in most cases.
- Last Name: Hunter
- Board Member Since: 2002
Exactly. Like most car radios, this set uses a non-synchronous vibrator with separate rectifier, so the input is not polarised. The only exception is a very few sets that used electrolytic filter capacitors on the 6V side. If it used a synchronous vibrator, then input polarity is important. Most such sets had a reversible vibrator, or a set of links to change over, to allow for either polarity.BE_ZERO_BE wrote: ↑Tue Feb 09, 2021 8:43 pm[size=150
[/size]
- First Name: Paul
Thanks John
After a year, I’ve contacted many radio people from online listings, but still have not found anyone up here that will retune it.
You will need to locate someone with antique radio experience. There are people who buy, sell, collect, and repair antique home and auto radios. I would not take the radio to a modern radio repair facility, if any such exist. It's most unlikely that anyone there has any experience with pre-WWII equipment, and most unlikely that anyone whold have any clue as to where to source parts. (It may be possible to use or adapt speedometer cables from 1940s-1960s cars to replace the missing control cables. It may have used commmon Stewart Warner speedometer cables.
A DuckDuckGo search for "Antique Car Radios" yields a number of possible sources of help. www.antiquecarradios.com looks like someone who deals with pre-WWII auto radios. Location is W. Virginia.
- First Name: Doug
- Last Name: Wilson
- MTFCA Number: 51005
I would ask for help on this site https://antiqueradios.com/forums/index.php. I have repaired a couple 30s and 40s radios, but am far from an expert.
Know there are folks on there that specialize in tube automotive radios. Much like this site often members share experience, pieces and parts that are no longer available to complete a restoration. Would post your request in the Antique Radio Discussion category. Let them know what if your looking for someone to fix it for you or if you want help to do it yourself. Photos are real helpful along with any numbers on the chassis, tube #s and count, etc.
- Last Name: Hunter
I restore vintage car radios like this, but unfortunately being on the other side of the world makes it a bit impractical.
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
You might also post on Fordbarn.com in the Early V8 section or https://forums.aaca.org/?_gl=1*14v7al4* ... 1646793887
With the control head mounted on the steering column, might have been Ford branded aftermarket. I get the impression from a quick look see in the Victor Page Ford V8 repair book, that factory supplied might have been mounted in the dash.
1920 Dodge touring
1920 Dodge touring
