Sick Dodge
Topic author - Posts: 6463
- MTFCA Number: 16175
- MTFCI Number: 14758
Sick Dodge
The old truck starts easily, with just a touch of the starter pedal. But it sure runs rough. The video doesn't do it justice. It sounds rougher in real life. I have a suspicion of what the problem is, but thought I'd ask if anybody has a suggestion of what to look for first.
https://www.youtube.com/watch?v=9BHrb4wGJ1k
- First Name: Ed
- Last Name: Martin
Re: Sick Dodge
Check if each plug is firing. Next do a compression check.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Re: Sick Dodge
Seems like a lot of smoke coming from the area between the manifolds, hopefully it's just the gasket and not a cracked manifold.
- First Name: Les
- Last Name: Gitts
- * REQUIRED* Type and Year of Model Ts owned: '11 Torpedo, '13 Towncar, '22 Centerdoor
Re: Sick Dodge
Sounds like a stuck valve. Those flathead sixes are notorious for having a valve stick after sitting all winter. Start with compression check. Might consider a running compression check to see if a valve spring broke.
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Re: Sick Dodge
Many years ago I had a 46 1 ton. In the summer it was very hard to start. An old timer told me it more then likely needed the starter serviced because it was drawing too much not leaving enough for the coil to fire.
1920 Dodge touring
1920 Dodge touring
- First Name: Robert
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
- MTFCA Number: 26459
- MTFCI Number: 20813
Re: Sick Dodge
Howdy, Steve. You might check for a cracked or carbon tracked distributor cap. Good luck. Bob
- Last Name: Grzegorowicz
- * REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
Re: Sick Dodge
MR STEVE, I'M A 83 YEAR OLD MECHANIC, AND HEARING THE ENGINE RUNNING, ITS MY OPINION THE CARBURATOR IS GUMMED UP, THERE ARE TESTS YOU CAN PREFORM TO ISOLATE THE CONDITION, OVER THE YEARS WHO KNOWS WHATS BEEN DONE TO THE POOR THING, IVE SEEN CARBON PLUG WIRES USED ,NOT GOOD FOR THE 6 VOLT SYSTEM AS WE ALL KNOW TO DAYS CORNAHAUL GAS SUCKS IN OLDER ENGINES BECAUSE THE OLD TIMERS SET AROUND MORE THAN THEY SHOULD, THIS GIVES THE GAS TIME TO LOOSE ITS GOODNESS, AND BREAK DOWN CAUSING MOISTURE TO SETTLE IN THE BOTTOM OF THE FUEL TANK, OLDER ENGINES THAT GET USED DAILY AVOID THIS SITUATION BEING THE GAS DON'T HAVE TIME TO BREAK DOWN, THE SINGLE BARREL CARB ON THE DODGE IS SO SIMPLE BUT THE PORTS ARE OR WERE OF A CERTAIN SIZE IN THE DAY, OVER TIME THEY BECOME SMALLER DUE TO THE BUILD UP OF CRUD CHANGING WHAT ITS JOB WAS DESIGNED FOR. MANY FACTORS ENTER HERE, RINGS WEAR, VALVES WEAR AND CARBON BUILD UP VALVE STEAMS WEAR CREATING VACUUM LOSS, AND SO ON, SO, AT FIRST DON'T TRY TO DIG TOO DEEP, CK COMPRESSION, THIS WILL GIVE YOU AN IDEA OF WHAT TO LOOK FOR NEXT, DO CK WIRES, IF THEY ARE CARBON REPLACE THEM WITH COPPER AS THEY SHOULD BE, SET POINTS TO 16 THO, BY ALL MEANS LOOK INTO THE CARB, THAT MAY BE THE REASON, SOUNDS TO ME LIKE A FEW OF THE 6 CYLINDERS ARE STARVING, OVER THE YEARS IVE HAD GREAT FUN MAKING A OLD WORN ENGINE RUN ITS BEST BY ADJUSTING MORE THAN REPLACING...GOOD LUCK, I HAD A D-100-YEARS BACK TOUGH OLE GAL...AFTER THOUGHT--WHEN ITS IDLING SPRAY CARB CLEANER ALONG INTAKE MANIFOLD GASKET MATING SURFACE TO THE BLOCK, IF NO CHANGE IS DETECTED IN ENGINE SPEED, THETE IS NO LEAKS.
- Last Name: Warren
Re: Sick Dodge
How are you doing on your truck? Definitely has a bad exhaust gasket on #1. Check the points and condenser. Also like said Check the cap. May just need points reset. They get where they stop opening.
Re: Sick Dodge
Some of the suggestions are along the lines of what I was suspecting. Thanks to all. I'll start checking into things when I have a nice day for working outside.
Re: Sick Dodge
It occurs to me I should report how this ended. I tested all the spark plugs under compression. #1 was intermittent and #2 was dead. Two new plugs were the answer.
Re: Sick Dodge
Thank you for sharing the solution and closing out this thread.
Re: Sick Dodge
Beside all the other things on the distributor, check the shaft bushings. When the bushings wear, the shaft wobbles and the point setting will change causing a dwell problem. In that case, you need either to rebush and maybe a new shaft in the distributor, or a rebuilt distributor. There is a MOPAR club. Maybe they can help you solve the problem.
