https://www.youtube.com/watch?v=ljCrxoLiPcY
Or were they a flat piece that was wound around a shaft?
Some model makers would like to have some little chain lik fence iguess.
Hyatt bearings, is this how they were made?
Topic author - Posts: 1523
- First Name: Herb
- Last Name: Iffrig
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Re: Hyatt bearings, is this how they were made?
Or were they a flat piece that was wound around a shaft? Flat and wound.
I got about 1/2 way thru the video, would have been nice to see what the end product was first then how they got to it. All that fine work, then they just lay the slit piece on the table to tap it, just holding it in their fingers?
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 1219
Interesting video.
Wikipedia tells me "helical-shaped rollers made from flat spring steel were more flexible than solid-cylinder rollers".
Years ago I thought they were just grooves in the roller until I found grease inside. I made rollers from drill rod for my Buick when I couldn't find the Hyatts. They work OK and I don't drive it much.
