Tail wagging the dog.
Topic author - Posts: 254
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926
- MTFCA Number: 29784
- MTFCI Number: 22970
The other day my wife and I were driving down the highway.
We came upon an F150 pulling a little trailer. It looked like it was for a ATV.
It was swaying from side to side.
I pull my T on a trailer and this got me thinking as to why the swaying back and forth.
The only thing I can think of is the axle was not on Square.
Am I way off or could there be another reason?
- Last Name: Nebelsky
- MTFCA Number: 49476
Re: Tail wagging the dog.
If the load is heavier behind the axle this could cause the swaying. Always put the heavier portion of the load in front of the axle, toward the tongue of the trailer.
- First Name: Greg
- Last Name: Popove
One morning, for no reason that makes sense at all, I pulled onto a freeway going against one-way traffic. I had gone a few miles before I was head-on to a pickup pulling a trailer. That was the microsecond I realized my error, and the pickup was a bit slow to respond but eventually swerved out of my way. I still remember seeing the trailer swaying back and forth in my rear-view mirror. It was another mile or two before i was able to cross over to the proper side of the divided highway. Good thing there wasn't much traffic that morning.
- Last Name: Juhl
- MTFCA Number: 50297
- MTFCI Number: 24810
Reminds me when I made a trip to the city a few years ago. My wife called and warned me that she heard on the TV that some nut was going the wrong way on the freeway.... "One, I said...there are hundreds of them!"
Another think which could cause a problem is a trailer without brakes. It will work fine when you are pulling, but if you have to stop fast, the trailer will try to push the truck. This would be worse with a light truck or car pulling the trailer. It could jackknife and push the truck to one side and then when you try to straighten it, could push the other way.
- First Name: Greg
- Last Name: Popove
I don't suppose it's legal anymore, but I saw a brake system that applied the brakes on the trailer when the towing vehicle decelerated, by compressing a piston in the hitch, which applied the trailer brakes.
Called a 'surge brake'. I don't know for sure, but as far as I know, they are still legal.
The most common reason for trailers swaying or oscillating is improper weight distribution. Weight either too high or too far back relative to the axle and hitch geometry.
I once was going up a steep hill, with a steep going down the other side, when near the top I saw an improperly loaded trailer swaying a bit while still going uphill. As close to the top as we were. I slowed down and kept a ways back. Going down the other side, the idiot (I am being kind here) sped way up to well above the speed limit. What made it worse, was anyone with half a brain could see traffic backing up and nearly stopped at the bottom of the hill! As soon as the idiot hit the brakes, the trailer broke into oscillation swinging from jackknife right to jackknife left and back again and again and again! On top of everything else the idiot did wrong, he wasn't in the right hand lane! Cars on the right of him and the left of him got hit multiple times! He clobbered at least three cars before he got stopped. And I wasn't sure, but I thought one of the cars he hit also hit a car in the next lane over when he in turn swerved as well.
I have seen way too many bad trailer accidents as they happened caused by people that have no clue how to load or pull a trailer!
- First Name: Rich
- Last Name: Bingham
Besides load distribution, height of the hitch point is a factor. Tongue pointing downward causes oscillation.
"Get a horse !"
- First Name: Leo
- Last Name: van Stirum
This is a short, simple and informative video about why a trailer starts to sway and takes over the car
https://www.youtube.com/watch?v=w9Dgxe584Ss
Leo van Stirum, Netherlands
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
Neat video find Leo! We've all Been There Done That (BTDT).
A level trailer loaded to the rear isn't any fun. I can believe it about a downward pointing trailer being naughty too.
Thought I had it about right one day with a 6500 pound load of an old tractor, some pressure on the rear bumper of the truck but nope.
About 35 mph was all I was comfy with and very gentle corrections.
Then other times when we get it right, 65-70 and it's smooth as glass.
- First Name: G.R.
- Last Name: Cheshire
- MTFCA Number: 29759
Surge brakes are still legal if you want to see for yourself rent a heavy U-Haul trailer. they are all equipped with them because most trucks don't have a trailer brake controller installed.
- First Name: Leo
Here's a more elaborate video about weight distribution in the car and the trailer and it's effects, the comments are in dutch but watch closely and it is self-explanatory
It is quite obvious what is going on as the demonstrator puts on and takes away weight at different places of the pulling vehicle and the trailer :
https://m.youtube.com/watch?v=KlD7THCoypk
