Want to buy a motor home, but, which one?
Topic author - Posts: 626
- Last Name: Seress
- MTFCA Number: 27707
I want to buy a used motor home to hook my trailer and model T to the back and be able to go to farther away from home model T tours. I was looking at around 30 foot long, class A diesel pusher. What advantage is a diesel pusher versus a front motor. What size motor, year and manufacturer is ideal. Is one manufacturer coach better built and more reliable over the other. Sorry but I have a lot of questions and only want to buy once.
Thank you in advance.
Frank
Frank
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Re: Want to buy a motor home, but, which one?
Talk to Dean Yoder and scrap this whole "towing" idea.
- First Name: Dennis
- Last Name: Seth
Frank,
You may want to look at renting a few for a weekend just to see what it like to drive the different types and styles and how they handle without towing a Model T anywhere. Just go camping in one or two a few times before investing in some style you later discover you're not happy with. That also lets you talk with the other campers in the park who have one and you can find out their likes and dislikes also.
- First Name: Leo
- Last Name: van Stirum
The obvious choice
Leo van Stirum, Netherlands
- First Name: Rich
- Last Name: Bingham
How about a custom sheep camp ? Provide a motor of your own choosing !
(5,000 sheepherders can't be wrong !)
"Get a horse !"
- First Name: Kenneth
- Last Name: DeLong
Your choices are as large as your checkbook and you can have anything you can pay for. Myself i used to haul our car trailer in back of our 5'th wheel camper. I have a friend with a diesel pusher and plates are approx 100 per month alone plus ins and other up keep. Usually a large diesel holds about 40 or 41 qts of oil so a change is costly! Another thing to think about with a large motor home is hauling a trailer and a large pusher can wreck a small trailer if not set up well?? Bud.
- First Name: G.R.
- Last Name: Cheshire
- MTFCA Number: 29759
I had a Front engine diesel (FRED) their selling point is they get better mileage than the pushers, i didn't find the difference to be anything to write home about. Hauling your model T behind a motor-home is not a bad experience as long as you have the trailer set correctly. The only problem I have ever had is that some states are very strict about how a registered antique vehicle can be used (they don't like to see you using them as a grocery getter from your campsite) but the good thing is most police officers don't know this and just want to talk about the neat old car. I had one stop me and inform me that in his state I could only drive the vehicle to and from a show, I played dumb and he let me go....... Personally I am looking for a racing trailer (goose neck) because i can haul my T and still have living quarters and I can disconnect my ram 3500 if needed for local trips to the grocery store and such.
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Can't help you on selection but do agree about renting one since your usage sounds sparse and their initial cost is high as is they depreciation quickly then level off. I was intrigued with this style of Winnebago models over the more common box/cab look. Don't need a BIG one for weekly joints.
https://www.winnebago.com/shopping-tool ... Id=PROD553
- First Name: Bill
- Last Name: Dizer
- MTFCA Number: 28610
In Indiana, regular license plates are only about $20.00 more a year than the highly restrictive (but rarely enforced) antique plates. With the regular plate, you can drive it any time and any where you care, without any questions. My insurance company does not care either. An added bonus is that the regular plates can be renewed on line, where the antique plate has to be renewed in person at the BMV. Well worth the extra not to have to deal with them in person!
- First Name: G.R.
Fortunately in Florida the antique tags are $65 and don't expire until the ownership expires.
- Last Name: Prince
- MTFCA Number: 22802
Meanwhile back at the topic... a motor home is a personal preference decision, I chose a class A because you set up higher so you can see more of the country side and it maximizes the interior space and the one I got has more ground clearance, I got a gas motor because I know 3 things about diesels, they are noisy, they stink and I don't work on them. I also wanted one without a slide out, while they give you more room they are also 1 more thing to break. I got a 27 ft Chevy Workhorse chassis with a 8.1 liter v8 and I get 10.4 mpg with out a trailer and 9.4 mpg with a trailer, it has plenty of power and I can still take to all of the National Parks, any bigger and they won't let you into some of them. That is what works for me, you might hate my set up so you just have to find what works for you.
- First Name: Dick
- Last Name: Cruickshank
- * REQUIRED* Type and Year of Model Ts owned: 1912 Depot Hack, 1916 Touring
I have had 4 motor homes in the passed. Each was gas which allowed me to service/work on/repair it and that finally became the issue to end motor home ownership. Most of the time a motor home sits idle for a significant amount of time. When the occasional use takes place, there seems to be something to fix or replace. I guess age has a factor but I would get nervous when I went to the shed to start the motor home and check it out prior to the trip. Batteries and tires were always in need of replacing (it seemed). Water and electrical issues were often a concern. I finally looked at the advantage of motor home vs motel and made the decision to end motor home ownership. I now pull a 24 ft enclosed trailer (eight feet high inside) so all my cars fit. I pull it with a 2500 Dodge crew cab and can use it to get around town when not using the T or other car in my stable. The cost of a motel (that offers breakfast) is usually less than the continued maintenance expenses of motor home ownership. Just my experience over a 40 year period. I don't expect everyone to agree.
