Help Wanted 2 cyl engine identification
Topic author - Posts: 60
- First Name: D
- Last Name: Brown
I was wondering if someone on here may be able to identify this engine. It’s two cylinder air cooled. No markings on it. Possibly came out of Canada. Sorry for the poor pictures not my engine.
- MTFCA Number: 1219
Re: Help Wanted 2 cyl engine identification
Well it's very intriguing and wonderful to see. High-wheeler comes to mind. Perhaps one of many forgotten brands or even made up from parts. The textured cooling fins are unique.
I'll bring it to the top and hope someone can tell us more.
Thanks for the pictures and another puzzle.
- MTFCA Number: 51486
I'd guess it's for a vehicle, maybe even an aircraft.
- First Name: Neil
- Last Name: Martin
Pat,
I wouldn't be keen to be the passenger in the aircraft.
Interesting that the starting handle must go between the magnets of the magneto to connect to the crank
My guess that could be off a1905/6 Reliable Dayton....Great Photos...N.
"I wouldn't be keen to be the passenger in the aircraft." /// I'd think Wilbur or Orville would have been happy to have been. They took to the air with less. That engine looks to potentially have a considerabley better power to weight ratio than typical early engines. Both intake and exhaust valves appear to be cam-operated. Many early engines had "automatic" intake valves, which operated off the pressure drop on the intake stroke. That simplified engine construction, but it limited power and speed and made intake valve timing uncertain. If this engine had much compression and any ability to rev, it would made good power but would also have needed a high velocity, high volume air stream for cooling. That would have been readily available in an aircraft application. The pilot would have to have dealt with oily goggles, but that was the way it was back then.
- Last Name: Morsher
It looks just a bit later than most highwheeler engines, but a possibility. The pressed on dimpled fins for cooling is something I’ve not seen before. A lot of railroad “speeders” used similar motor. Lots of companies in Indiana made engines , and I’ve had luck searching their old advertisements. Good luck, keep us posted as to what you discover.
- First Name: Herb
- Last Name: Iffrig
In the last picture it looks like it works on vacuum.
Upper valves are intake, and appear to have pushrods & rockers. Lower valves are exhaust, and also have rockers. Exhaust turned upward seems a little odd for a road going vehicle with the engine mounted underneath, but all is speculation.
Chevrolet made an air-cooled engine with composite cylinders for a year or two. See: "Copper Cooled Chevrolet"
- First Name: D
- Last Name: Brown
Couple things I should mention. The magneto mount and position may not be original. If you look closely those are actually wooden blocks on either side of the mag.
Also the crankshaft extends about 24 (just guessing) inches out the other side. It also has a couple woodruff key slots milled into it along with a couple dimples for set screws. This would lead me to believe it’s not aircraft.
- Last Name: Nunn
- MTFCA Number: 50321
The crankcase is small for the length of the cylinders. It can't have much of a crank throw or balancing weights, if present.
The small crankcase suggests a short stroke, but the length of the cylinders doesn't. No flywheel, or indication of any? Being out of Canada,it may be of British make. It would be interesting to know the bore/stroke and compression ratio. I don't see much indication of mounting bosses for shrouding such as a stationary or automotive air cooled engine would require. It may not have ever had a starting crank.
- Last Name: Hanlon
- MTFCA Number: 50191
My first thought was aircraft. Wouldn’t need a crank if you could spin the prop.
This one is intriguing. Thanks for the additional info. The crankshaft appears it likely had a planetary transmission attached. The oiler looks pretty industrial and could have been added,as you mentioned the mag placement. IMHO too heavy for a lightweight design. Also, the bore is not straight, so the rods would not have to be offset, which is a pretty early design flaw( straight bore, that is )
I looked for a long time last night and thought possibly European as they had some really wacky stuff. Cycle car is a possibility, as also some really strange ones. I even thought motorcycle, but the big mounting casting still leads me to believe some sort of industrial use.
Chevrolet lost their shirt on a copper finned air cooled project, and something to remember, often very rare things ( in all fields) were sometimes because of poor design.
Is there a make of the oiler, or might be good to research that. It’ll help pin down where the motor was made, if the oiler appears it’s always been aboard .
If it's an airplane motor, I doubt if it had a prop mounted on the crankshaft. That thing looks too large and expensive for a cycle car.
- MTFCA Number: 52564
Try posting here;
https://www.smokstak.com/forum/forums/s ... ngines.27/
1920 Dodge touring
1920 Dodge touring
The mechanical oiler looks much like the Kinwood's used on Overland's. The cap and drip adjustment are very similar.
Patent dates '06 and '08 are shown and they were used as late as 1913 or so.Rich
