Pony Tank CO2 MIG Shielding Gas Regulator?
Topic author - Posts: 913
- First Name: Ignacio
- Last Name: Valdes
- MTFCA Number: 50406
I have a CO2 pony tank that I want to use for MIG. However, my usual gas regulator adaptor is too big, see picture. I have this other regulator that came with the tank but I am not sure how it works. It has an attachment with a power cord on it. No markings or manufacturing number on it. Can I use it? If not what regulator or adaptor should I get to use this? The input to the Chicago Electric MIG is simply a tube with a zip tie to keep it snug.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: Pony Tank CO2 MIG Shielding Gas Regulator?
Hi Ignacio,
Most welding shops sell the CO2 adapter. My thought is does the welder have a gas solenoid biult in? Some Migs come set up for flux core wire only. If not then the solenoid will be needed to turn the CO2 on & off as you weld. If it has a solenoid biult in then you should be able to just remove it. Shielding gas is not cheap so make sure no matter how the hose is conected it does'nt leak. looks like you are on the way to being a welder. Good luck.
- Last Name: Valdes
Truth be told I found a CO2 tank on the curb and did a swap with Praxair for the current certified filled one. The regulator came with it and might/probably is a kegger type. Is that 'ok' to use? I would think a regulator is a regulator.
- Last Name: Valdes
The electric cord gizmo on the CO2 regulator is a mystery to me though. What might it be for?
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
You find cool stuff on the street! Me it's refrigerators, stoves and maybe lumber. Oh wait, I did find a big screen flat TV. Mom does not like them, people are too life sized! LOL
1920 Dodge touring
1920 Dodge touring
- Last Name: Valdes
Yes I figured out the corded item was probably a pressure switch so I took it off. I removed a stuck gauge needle and replaced it in the zero spot will it work? Answer is yes. Found the last fitting needed in the to return to shelf box of odds and ends. MIG worked pretty well once I was able to get this on. Not bad for only a few dollars. I love curb finds when they work out.
