Looking for thous who know,Warning>> Completely OT
Will
First Name: Will
Last Name: Copeland
Post by Will » Tue Apr 02, 2019 3:29 pm
I am considering buying a new 22/250 strictly to poke holes in paper.. Iv been reading a lot about barrel size and rate of twist versus weight of the bullet. The rifles Iv looked at within my budget mostly have a 22 inch barrel with a 1 in 12 twist rate. From what iv read any rifle with less than a 24 inch barrel needs a 1 in 12 twist rate with rounds of more than 40 grains for the greatest stability. I seen one rifle with a slower twist rate of 1 in 14 with a 22 inch barrel. Would this be better than the 1 in 12 twist. Or should I be considering a faster rate like maybe 1/10? I would like to use this rifle at the 200 yard range. What twist rate would be best used for 200 yards? At some point I would be reloading the rounds so I would want to match the rounds with the twist rate, bullet weight, powder type and barrel length. Should I not be quite so concerned about the rifle and be more concerned later when I match the rounds to the rifle? Thank you.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Re: Looking for thous who know,Warning>> Completely OT
Post by Dallas Landers » Tue Apr 02, 2019 4:30 pm
I have a Savage 22-250 `with 1 in 12 twist. I load a 50 grain nosler polimer tip for varmit. Its very stable to 400 yds. After that it starts to get a little wild. Wind doesnt seem to effect it much because its so fast.
I use 1 in 8 twist for my 243
1000 yd guns.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Apr 02, 2019 4:37 pm
I will check barrel length when I get home
Will
First Name: Will
Last Name: Copeland
Post by Will » Tue Apr 02, 2019 5:19 pm
Dallas, What brand powder do you use and at what grains? Also, What brand primers do you use. Im always looking for something better.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Apr 02, 2019 5:52 pm
Winchester case
Winchester primer
35.1 grains of RL-15
50 grain Nosler varmit polimer tip.
Savage model 10. 22-250
With 22 inch fluted barrel.
The accue trigger is great on the Savage.
Will
First Name: Will
Last Name: Copeland
Post by Will » Tue Apr 02, 2019 8:44 pm
I recently bought a 17cal savage with the bull barrel. I set that accu trigger feather light. The only thing I dont like about it is its a bear to clean.I ended up buying a solid brass rod to drive the brush and wadding down the barrel. I'm waiting for the wind to calm down some here in Florida so I can get back on target. Im looking forward to trying the 17 on the 200 yard range when the winds settle down. I also have a savage 6.5 Creedmoor. The winds were gusting around 30mph and the Creedmoor put the rounds on target at 200 yards. There is a 400 yard range about an hour from me that will let me shoot bench and I want to stretch the creedmoors legs a little. We have a 600 yard range here but Im no longer able to shoot prone due to a neck problem so its bench from now on.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Apr 02, 2019 8:56 pm
I have a Savage 17 and love it. I have killed ground hogs at 200. I shoot Hornaday red tips 32 grain. Only problem is it comes apart if you hit a blade of grass. I tried 40 gr but it doesnt shoot as good as 32 gr. That small bore is tight.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Apr 02, 2019 8:58 pm
I am lucky to have a 1000 yd range a mile from me. The unlucky thing is since I got the T I havent taken time to shoot.
Will
First Name: Will
Last Name: Copeland
Post by Will » Tue Apr 02, 2019 9:26 pm
I take my T to the range very often. The guys love it when I show up in it. My gun cases stick up over the seats but I still go. of course the down side to that is I can stop anywhere with the guns in the T. I would love to try a 1000 yards once. I would have to use a better scope though. Right now mine is set for two dots elevation for 200.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Apr 02, 2019 9:36 pm
I must be tired, the 32 and 40 gr v-max is for my 204 ruger. I have taken the T to the range and it gets lots of attension.
