Looking for thous who know,Warning>> Completely OT
Topic author - Posts: 82
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
I am considering buying a new 22/250 strictly to poke holes in paper.. Iv been reading a lot about barrel size and rate of twist versus weight of the bullet. The rifles Iv looked at within my budget mostly have a 22 inch barrel with a 1 in 12 twist rate. From what iv read any rifle with less than a 24 inch barrel needs a 1 in 12 twist rate with rounds of more than 40 grains for the greatest stability. I seen one rifle with a slower twist rate of 1 in 14 with a 22 inch barrel. Would this be better than the 1 in 12 twist. Or should I be considering a faster rate like maybe 1/10? I would like to use this rifle at the 200 yard range. What twist rate would be best used for 200 yards? At some point I would be reloading the rounds so I would want to match the rounds with the twist rate, bullet weight, powder type and barrel length. Should I not be quite so concerned about the rifle and be more concerned later when I match the rounds to the rifle? Thank you.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Looking for thous who know,Warning>> Completely OT
I have a Savage 22-250 `with 1 in 12 twist. I load a 50 grain nosler polimer tip for varmit. Its very stable to 400 yds. After that it starts to get a little wild. Wind doesnt seem to effect it much because its so fast.
I use 1 in 8 twist for my 243
1000 yd guns.
1000 yd guns.
I will check barrel length when I get home
- First Name: Will
Dallas, What brand powder do you use and at what grains? Also, What brand primers do you use. Im always looking for something better.
Winchester case
Winchester primer
35.1 grains of RL-15
50 grain Nosler varmit polimer tip.
Savage model 10. 22-250
With 22 inch fluted barrel.
The accue trigger is great on the Savage.
Winchester primer
- First Name: Will
I recently bought a 17cal savage with the bull barrel. I set that accu trigger feather light. The only thing I dont like about it is its a bear to clean.I ended up buying a solid brass rod to drive the brush and wadding down the barrel. I'm waiting for the wind to calm down some here in Florida so I can get back on target. Im looking forward to trying the 17 on the 200 yard range when the winds settle down. I also have a savage 6.5 Creedmoor. The winds were gusting around 30mph and the Creedmoor put the rounds on target at 200 yards. There is a 400 yard range about an hour from me that will let me shoot bench and I want to stretch the creedmoors legs a little. We have a 600 yard range here but Im no longer able to shoot prone due to a neck problem so its bench from now on.
I have a Savage 17 and love it. I have killed ground hogs at 200. I shoot Hornaday red tips 32 grain. Only problem is it comes apart if you hit a blade of grass. I tried 40 gr but it doesnt shoot as good as 32 gr. That small bore is tight.
I am lucky to have a 1000 yd range a mile from me. The unlucky thing is since I got the T I havent taken time to shoot.
- First Name: Will
I take my T to the range very often. The guys love it when I show up in it. My gun cases stick up over the seats but I still go. of course the down side to that is I can stop anywhere with the guns in the T. I would love to try a 1000 yards once. I would have to use a better scope though. Right now mine is set for two dots elevation for 200.
I must be tired, the 32 and 40 gr v-max is for my 204 ruger. I have taken the T to the range and it gets lots of attension.
