My drill press quit, so I decided it was time to replace the 50+ year old wiring. My press had a reverse switch added in the 60’s and the insulation on the wiring was old, cracked. It also had a toggle switch that was like a happy dogs tail, loose and floppy.
So I went on the chase to fix and replace old wiring.
What a rabbit hole I have dove into, being that my skill with electrical stuff is on par with a flying a kite on a windless day.
I will eventually get this back together, but I think I’ll go fishing tomorrow instead.
Am I alone at procrastinating problems?
Robert Bente
Redding, ca
Replacing wiring on a drill press
Topic author - Posts: 74
- First Name: Robert
- Last Name: Bente
- * REQUIRED* Type and Year of Model Ts owned: 1916 runabout, 1921 touring, 1915 touring
- MTFCA Number: 49948
- First Name: Rich
- Last Name: Bingham
Re: Replacing wiring on a drill press
I might tell you all about my procrastinating ways . . . Tomorrow.
I like to dress it up as "the art of intelligent neglect", aka "prioritizing".
Get a horse !
- First Name: David
- Last Name: Dewey
- MTFCI Number: 19936
Robert, I was going to post you here, but I just never got around to it. . . . .
T'ake care,
David Dewey
David Dewey
- First Name: Dick
- Last Name: Fischer
- * REQUIRED* Type and Year of Model Ts owned: 1912 Touring
I replaced the wiring on my Made in China drill press about 5 years ago. What a mess ! The wiring in the head was all single strand, very small gauge,and some of it had no insulation at all. Looked to me that somebody picked scraps off the floor and soldered it all together as necessary to go from point A to point B. When I got done the work light stayed on constantly, but that's OK. Reminds me to unplug the fire hazard whenever I go in the house for the night.
- MTFCA Number: 52564
Black is hot, white is common, green is ground. Switches go in the hot (black) lead.
1920 Dodge touring
1920 Dodge touring
