1903/04 model A
Topic author - Posts: 209
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
- MTFCA Number: 32419
1903/04 model A
Where on these vehicles can I locate a serial number ect. And any other info would be great on this early model, thanks in advance.
- First Name: Herb
- Last Name: Iffrig
Re: 1903/04 model A
The serial number can be found on the face of the fly wheel and possibly on the bearing caps, like on the cap that is on the frame where the crankshaft rests.
Carlton Pape wrote a book on the Early Fords called The Early Ford Encyclopedia. There is a lot of information in there about the location of serial numbers.
You could also get on the club website for early Fords:
https://earlyfordregistry.com/
There is a forum there where any question about these cars could be asked.
https://earlyfordregistry.com/phpBB3/vi ... 164be7b8e8..
Good luck. Send me a note if you need help. I'm vice president and can help you if needed.
- Last Name: Wendt
Re: 1903/04 model A
Thank you Herb, that # info is what i need.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Re: 1903/04 model A
If you can find a copy, get the book "Pate's Early Ford Encyclopedia", it is full of information on early Fords. Be sure the copy you get still has the CD in the pocket on the back cover with lots of extra information not in the print book.
- Last Name: Wendt
Re: 1903/04 model A
Thanks Herb & Mark, Langs had one on the shelf should see it by wed.
