- You need to worry about installing a specific camera plugin to use the OBS virtual webcam on your Mac, as the virtual camera feature is built into the latest version of the software. So, to start the process, you just need to download and install the latest version of OBS Studio. You can download directly from the OBS site or open your already-installed app and click Help > Check for Updates.
The next step of how to set up the OBS virtual camera on Mac is to set up the various scenes and sources you wish to use later on in Zoom calls, Skype meetings, and so on. To do this, just go to the Sources box at the bottom and click + and then select a source you wish to add, like a Media Source or Display Capture.
Once the sources and settings have all been configured, you can activate the virtual camera. To do this, go to the Controls section in the bottom right of the OBS window and click Start Virtual Camera to enable the cam. Therefore augmented Reality quite helps in virtual camera setup because most of the AR VR companies provide the best Augmented Reality Development Solutions that helps to manipulate the camera.
How to set up an OBS virtual cam plugin on a Mac
Topic author - Posts: 1
- First Name: Rana
- Last Name: Adnan
