What temp/How long do I heat HDPE pipe and fitting for plastic weld?
Posted: Sun May 05, 2024 12:49 am
Hi all, I am retrofitting a faulty ground source heat pump system. I have received this new plastic welder from amazon. The sockets appear correct for US pipe (inches not millimeters). The documentation is sparse. What temperature do I set the welder to melt HDPE pipe? How long do I heat at that temperature a 1 inch and 1.25 inch HDPE pipe and fitting before fusing together?
