RMS Titanic 1:100 Scale Model - Construction Montage
Posted: Sun Jun 02, 2024 1:39 am
by ModelTMitch
Since some of you had noticed the 🚢 Titanic model in the background of my most recent video with @flivverchannel, in which Steven and I discussed the Model T hobby at quite some length—I thought I'd share this photo montage of the model under construction.
https://www.youtube.com/watch?v=Roxyddhucng
On April 20th, 2020, with my sister’s assistance, the keel was laid down for the construction of the RMS Titanic—well ok not full size I admit! It’s built to a scale of 1:100. At 2.7 metres in length, it’s longer than my dining table! She was “launched” on August 20th 2020, four months after construction commenced.
Construction is almost entirely cardboard. The model consumed more than 400 hot glue sticks, 14 sheets of A1 size 600gsm cardstock, at least 2 litres of paint, many metres of copper wire and cotton thread plus countless matchsticks. To ensure strength, as the cotton rigging is under tension, the masts consist of bamboo kebab sticks hot-glued together in clusters and concealed in paper tubes.
Solid core copper house wire was stripped and cut to size to create the hand railing, for which each rail was tediously hot-glued to tooth-pick uprights—literally hundreds of glue joints! Each and every port hole was meticulously measured and hole-punched in the correct place on each hull plate before each plate was hot-glued into place on the corrugated cardboard frame.
Just like the real ship, the model has a keel, in this case, comprising 6 layers of corrugated cardboard, held together with hot glue. The entire model is illuminated at night by over 450 micro LED’s. The completed model weighs in at just 7 kilos—a little less than the 46,000 ton original!
Re: RMS Titanic 1:100 Scale Model - Construction Montage
Posted: Sun Jun 02, 2024 7:52 am
Amazing.... !!
Posted: Sun Jun 02, 2024 8:25 am
by perry kete
What a great story and video as well as a beautiful model.
Thanks for sharing this.
Posted: Sun Jun 02, 2024 10:54 am
by tdump
Holy mackerel , i don't have the talent for such quality work, that took HOURS and HOURS. How do you move it around? is is sturdy enough to pickup without fear of damage?
Do you transport it to any type of shows?
Posted: Tue Jun 04, 2024 7:10 am
by su8pack1
Looks great.
Posted: Fri Jun 07, 2024 1:17 pm
by hull 433
Almost as big as the builder's model!
Posted: Sat Jun 08, 2024 2:17 am
by ModelTMitch
It hasn't been to any shows yet, and I think transporting it would be tricky as it's a free standing model, I didn't factor in any tie-down points!!
I guess I could always drop the anchors...
It only weighs about 7 kilograms (14 or 15 lbs), so lifting it isn't a problem, its keeping it steady during transport!!
tdump wrote: ↑
Posted: Sat Jun 08, 2024 10:38 am
by tdump
you could probably put a few layers of thin plastic sheeting around it and then spray foam a "bed" for it to sit in, then when the foam dries just lift out,remove the plastic and be able to set it in and out of the "bed" when you want to haul it.test this idea on something LESS meaningful in case there is a unforeseen issue.
Posted: Tue Jun 11, 2024 1:27 pm
by 1925 Touring
Wow, It certainly looks great!
The video really shows how it was put together nicely!
Posted: Sat Jun 29, 2024 6:02 am
by ModelTMitch
That's a good idea, something like expanding foam, but ideally something that doesn't dry harder than a bull's forehead! It needs something soft-ish. But I like the thinking, use the model itself as a mold and protect it with a plastic film.
I haven't even considered showing it to be honest, that YouTube video is kind of its maiden voyage - minus the sinking part :D
tdump wrote: ↑
Posted: Sat Jun 29, 2024 10:48 am
ModelTMitch wrote: ↑
tdump wrote: ↑
Does the hull have the rigidity to resist the expanding foam? I'd hate to see the expanding foam crush the hull, (or at least distort it).
Posted: Sat Jun 29, 2024 12:48 pm
Manually sculpting out a nest for the hull in foam could work. A display table could be made up with foam panels with their surfaces sculpted to look like waves and a wake, and a space carved out to allow the hull to set down into it to the waterline. If the foam panels were made in two pieces, they could be easily put in place to display the ship "at sea" or removed to reveal the entire model. Styrofoam panels in various thicknesses used to be available, and it could be carved and shaped as desired with hand tools and a Dremel tool or a hand drill with rotary rasps.
