Rust removal
Rmilytaxm
First Name: Luigi
Last Name: Anderson
Location: https://rustconverters.net/metal-rescue-rust-remover/
Rust removal
Post by Rmilytaxm » Wed Sep 18, 2019 9:39 am
Can anyone recommend something to remove rust on a chrome heated towel rail? I am using a combination of brillo pad, peek, astonish, and some bicarbonate of soda abrasive cleaner.
Is there anything to get rid of it quickly?
PDGx
First Name: Paul
Last Name: Grohsmeyer
MTFCA Number: 27359
Re: Rust removal
Post by PDGx » Fri Sep 20, 2019 8:59 am
If that didn’t work, use some STAINLESS STEEL wool. Stainless won’t scratch the chrome, but will remove the rust.
DO NOT use regular steel wool as it WILL scratch.
Or you can wipe it with Evapo-Rust to remove light rust.
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
Can’t, ain’t Possible
‘17 TT / Holmes Wrecker
‘22 Mack AC
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Rust removal
Post by D Stroud » Sun Sep 22, 2019 4:13 am
I have used Brillo or SOS pads to remove rust from chrome for 60 years, works great for me and is quick. You are using the Brillo pads with water aren't you? Don't know how you could get much quicker. JMHO Dave
1925 mostly original coupe.
