Can anyone recommend something to remove rust on a chrome heated towel rail? I am using a combination of brillo pad, peek, astonish, and some bicarbonate of soda abrasive cleaner.
Is there anything to get rid of it quickly?
Rust removal
Topic author - Posts: 1
- First Name: Luigi
- Last Name: Anderson
- Location: https://rustconverters.net/metal-rescue-rust-remover/
- First Name: Paul
- Last Name: Grohsmeyer
- MTFCA Number: 27359
Re: Rust removal
If that didn’t work, use some STAINLESS STEEL wool. Stainless won’t scratch the chrome, but will remove the rust.
DO NOT use regular steel wool as it WILL scratch.
Or you can wipe it with Evapo-Rust to remove light rust.
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
17 TT Holmes Wrecker
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor
30 A Rdstr PU
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Re: Rust removal
I have used Brillo or SOS pads to remove rust from chrome for 60 years, works great for me and is quick. You are using the Brillo pads with water aren't you? Don't know how you could get much quicker. JMHO Dave
1925 mostly original coupe.
