How to move a clock ?
Topic author - Posts: 2789
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
I know there are some clock experts here. My wife has inherited her grandmothers grandfather clock. Not extremly old but I need to bring it home. Do I need to remove weights, keep upright ect...
I do not want to damage anything. Thank you.
- First Name: Bill
- Last Name: Chuplis
Re: How to move a clock ?
I'm not an "expert" but this is how I've successfully moved a few.
The weights and the pendulum (and chimes tubes if applicable) should be removed (wear cheap white gloves) and wrapped in towels.
If chain driven, the chains can be tie-wrapped tight under the seat board to keep them from falling off the sprockets. If cable driven, install an eye screw in the bottom the case (might be one already there) and tie them off snug with some string to keep them in place.
Finals and bonnets should also be removed and stowed.
With chime/strike rods, place rags or some Styrofoam between them and the hammers and between each other.
Professional movers usually ship upright but they're equipped to do it safely. I've never had any problem with them lying flat on their back but never had to go more than 30 miles. Good luck!
- First Name: Bob
- Last Name: Doris
- * REQUIRED* Type and Year of Model Ts owned: 1926 Runabout, 1930 Sport Coupe
- MTFCA Number: 32538
All of the above excellent suggestions. Be especially careful with pendulum removal and reinstallation so as not to damage the pendulum suspension spring. They can be easily damaged. Make sure the suspension spring is protected during the move.
Thank you gents!
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
If at all possible, ship upright. Remove pendulum and weights, if this does not cause
tangling issues. Taping, zip ties, and stuffing can be useful to safely controlling the
swinging parts from damaging themselves or nearby parts. The kicker is, you want to
freeze everything as it would normally hang there, during the move. How you achieve
that end can take many paths. Bottom line, swinging parts beat each other up. Getting
them tangled is bad. Keep that from happening, you are good to go !
- First Name: Dennis
- Last Name: Seth
Tell the darn clock to move itself! It has it's own hands!
- First Name: CHARLIE
- Last Name: BRANCA
- MTFCA Number: 28967
- Board Member Since: 2010
But no feet. what do you expect it to do ? Crawl ?
I wish it would walk. Running is dangerous!
- Last Name: Seth
A clock isn't any good if it isn't running!
Yes it can walk on it's hands and not crawl.
