What is it?
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
What is it?
Post by ivaldes1 » Sun Jan 26, 2020 7:10 pm
Found these in a bunch of automotive parts. What could they be?
MTFCA Number: 1219
Re: What is it?
Post by Rich Eagle » Sun Jan 26, 2020 7:18 pm
One of these.
https://www.bing.com/aclick?ld=e3pKGFmX ... dlt=strict
Car AN8 90 Degree Gas Oil Fuel Hose Line End Fitting Adapter Hose Connector
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Re: What is it?
Post by Burger in Spokane » Sun Jan 26, 2020 7:56 pm
They were only used on the two pedal cars.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Re: What is it?
Post by Oldav8tor » Mon Jan 27, 2020 11:25 am
Look like what I've used on airplanes for fuel lines, oil lines and brake lines in areas where rigid lines are not acceptable.
1952 Willys M38a1 Jeep
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: What is it?
Post by Ruxstel24 » Mon Jan 27, 2020 12:17 pm
I’m pretty sure they are high pressure oil pump lines from the HPOP to the cylinder head/fuel injectors on a Ford 7.3 Powerstroke diesel.
