Wanted: front axle repair
Topic author - Posts: 40
- First Name: Leonard
- Last Name: Hochendoner
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup
- MTFCI Number: 25544
I have a 27 that needs upper and lower king pin inserts on the right side.
I don't have the tools, so I would need to buy all that just for one repair.
It would suit me better if I could bring the axle somewhere and have it done.
I can remove the axle and bring it to a shop within a couple hundred miles or so.
My zip is 26105 (Parkersburg, WV; Marietta, OH) area.
PM or email or call (304) two nine 5 - seven seven 2 four.
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: Wanted: front axle repair
If it’s actually a ‘27 axle, they are typically quite a bit harder and odds are you might just end up breaking the tapered reamer. They can be kind of dicey to use the Stevens tooling on unless you are quite experienced. My recommendation would be to find a better axle.
- Last Name: Hatch
- MTFCA Number: 49974
Check your email. Sent a contact of someone close to you. Also you ship them by ups. Not to bad depends on how far. Dan
- Last Name: Nunn
- MTFCA Number: 50321
I have the same need as Leonard with my '26 Runabout's front axle. I have searched, unsuccessfully, my contacts in eastern Nebraska for someone who can do the repair. I can send it to Model T Haven for repair but I would like to find someone within a few hours drive.
If anyone in eastern Nebraska or western Iowa wants to earn some cash, send me a PM or email through the forum.
Sorry for hijacking your thread, Leonard.
Mark,
Not at all, that's what it's for. The more the merrier.
The more attention this thread gets the better the chance we all get our axles fixed.
Also, you may want to see my post under parts, for a sevens axle tool.
You may see some useful information or options there.
- Last Name: Hatch
I repair front axle. Install Stevens. Inserts, weld and face the yokes also straighten. Will also install and machine bushings in spindle. My zip is 35173. Thanks Dan
worthy of a bump
NH Full Flow Float Valves
- First Name: Jason
- Last Name: Walters
Bump to top
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
