Hi folks. I have tooling for rebuilding front axles and steering assemblies. I check to see if axle is bent, put new bushings in front axle, new bushings in spindles, spindle arm bushings, I can do spring bushings too. Need new wheel bearings? How about a repair on your hub cap threads?
My shop is about 30 minutes north of Detroit, Michigan (via modern car on interstate). It would take about 1.5 hours in a model T from downtown Detroit.
Best way to reach me, Seamus, would be by email at smh.restoration@gmail.com.
Front Axle Rebuilds
Re: Front Axle Rebuilds
worthy of a bump
NH Full Flow Float Valves
- First Name: Jason
- Last Name: Walters
Bump to top
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
Topic author - Posts: 42
- First Name: Seamus
- Last Name: Hnat
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford T Touring & 1912 Ford T Speedster
UPDATE:
I will be moving and will be about 1 hour north of Detroit (via modern car). I don't know how to edit post. I can do more than just front axles too. I have UPS shipping account too for cheaper shipping rates if you want I can send you a shipping label to get parts to rebuild to me.
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Seamus,
Pull up your original post. To the right of the headline you will see three boxes. The first one is a pencil. Click on that and you can edit your post.
