First New Vane Actuators Fresh off the Assembly Line
Topic author - Posts: 458
- First Name: Mike
- Last Name: Kossor
- MTFCI Number: 22706
Just inspected the first samples of the Vane Actuators from a new run. The workmanship, quality and machining tolerances are all excellent with window edge to window edge machining tolerances well within the specified +/- 1 degree tolerance. This is very important because it determines the cylinder to cylinder ignition timing accuracy and consistency.
Mechanical tolerances were verified by electrical performance test using the E-Timer and its specially designed test set. Cylinder to cylinder timing error is less than +/- 0.4 degrees. Note that Automatic Timing Advance remains active and accurate from 400 RPM to 3500 RPM during this timing accuracy test operating on 12VDC battery.
Please pass this information along to other interested parties. I am prohibited from posting this accomplishment on the discussion forum being the vendor who designed, developed and markets this item.
- MTFCA Number: 51486
Re: First New Vane Actuators Fresh off the Assembly Line
That's probably more accurate than the piston timing at most speeds and loads.
- Last Name: Nunn
- MTFCA Number: 50321
E-Timer running on 12 Volts? I thought the E-Timer was built for 6 V only. I just installed an E-Timer but have not driven my car beyond my driveway yet. I use a 6 V battery.
- First Name: Mike
- Last Name: Kossor
The E-Timer was designed to operate on 6V, 8V, 10V or 12V battery. The computer monitors the operating voltage and adjusts coil timing for optimal performance automatically.
worthy of a bump
NH Full Flow Float Valves
- First Name: Paul
- Last Name: O'Neil
- MTFCI Number: 18018
I do not understand what this part does. Does it make the E-Timer work better? I'm curious because both of my cars have E-timers.
Paul
Paul
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
Bump ….
FJ
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
