Posted: Mon Jul 05, 2021 9:54 pm
NH Full Flow Float valves in stock
No more obsolete parts being made for sale. Only new NH Full Flow Valves are in production.
Last of these kinds of parts are now gone:
Re: NH Full Flow Float Valves and Obsolete Carb parts - this job is done
Posted: Thu Jul 08, 2021 7:30 am
by Mark Nunn
Scott, after installing your float valve in my '26 I opened my tank's fuel valve. I didn't hear the normal tinkle sound of fuel entering the carb bowl. I thought I had an obstruction of some sort. It turns out that the fuel flowed in a stream instead of a dribble. I've only driven 10 miles since then because I'm still chasing some front axle problems so I don't have an objective evaluation yet.
Posted: Wed Sep 29, 2021 6:24 pm
by JWalters
Bump to top
Posted: Sat Oct 09, 2021 6:27 pm
by FreighTer Jim
Bump ….
FJ
Posted: Thu Mar 10, 2022 9:05 am
by Dallas Landers
To the top for a guy making a great part for the hobby.
Posted: Wed Apr 20, 2022 5:07 pm
Stromberg OF parts:
Idle Jets
Choke Springs
Economizer Valve
Economizer Lever Pivot
Adjuster Well
Re: NH Full Flow Float Valves and Obsolete Carb parts manufactured
Posted: Thu Apr 21, 2022 9:37 am
by Quickm007
Impressive Scott!
Posted: Fri Apr 22, 2022 11:36 am
by BE_ZERO_BE
That is true A.S.N. quality !! (At-Sa-Nicea) :lol:
Posted: Tue Jun 14, 2022 8:41 pm
Fuel inlet bolt and fitting for Zenith U6 for RAJO "B" copied from an original taken from it's little brother, a U5...serious ZOOMING to occur soon
Posted: Fri Sep 09, 2022 11:40 pm
by TRZim
You still have the NH enlarged seat for fuel pressure by the float to open and close? I bought one from you I now need another.
Re: NH Full Flow Float Valves now in stock, and Obsolete Carb parts manufactured.
Posted: Sat Apr 22, 2023 11:03 pm
Fun stuff made this winter: Zenith S4BF jets and springs
Posted: Sat Apr 22, 2023 11:16 pm
specialty work requires specialty tools (now you know why there's a notch in the mounting flange):
