This Model T Exploded!
MichaelPawelek
Topic author - Posts: 712
- First Name: Michael
- Last Name: Pawelek
Andy
- First Name: Andrew
- Last Name: Drake
- * REQUIRED* Type and Year of Model Ts owned: '12 Touring / '24 Coupe
Re: This Model T Exploded!
That looks and awful lot like the one at The Henry Ford Museum and Greenfield Village.
BobD
- First Name: Bob
- Last Name: Doris
This one taken at The Henry Ford Museum 2018.
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
- Last Name: Juhl
Why are the demountable rims displayed inside the wheels? Shouldn't it be the other way around?
Ruxstel24
- Last Name: Hanlon
Loose nut in the flywheel maybe ?
Hit a California pothole.
MichaelPawelek
Must be a Southern Wide Track!
George Andreasen
- Last Name: Andreasen
- * REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Actually, this was Henry's first attempt at what he called a "stationary assembly line". The idea was to drop all the parts in one place and have a completed car. Alas, it didn't fare too well.
I understand the Ford engineer who came up with the idea was dismissed not long after........................
Mark Osterman
- Last Name: Osterman
I have seen that several times in the Science Museum in London right across the street from the Victoria and Albert Museum.
BobD
- First Name: Bob
- Last Name: Doris
I personally took the above photo at The Henry Ford Museum in Sept. 2018.Mark Osterman wrote: ↑Thu Feb 21, 2019 6:40 pmI have seen that several times in the Science Museum in London right across the street from the Victoria and Albert Museum.
Mark Osterman
Ha ... I see that one is at Henry Ford Museum .. not the Science Musem. So evidently there is more than one. The Duetches Museum in Munich may have one too. Everything in that place is cut in half!
VowellArt
- First Name: Martynn
- Last Name: Vowell
- Board Member Since: 2012
The wheels and rims are still in the wrong positions...you'd think somebody would fixt that.
Fun never quits!
BobD
- First Name: Bob
- Last Name: Doris
Looks like it would be a relatively easy fix.
Mindless Automaton
- First Name: Kep
- Last Name: Kerensky
- * REQUIRED* Type and Year of Model Ts owned: 23 truck, 26 bug
- Board Member Since: 2011
It'd be funny if both museums had the rims assembled incorrectly.
Chris Barker
- First Name: Chris
- Last Name: Barker
Hmm. The shut lines aren't too good
D Stroud
- Last Name: Stroud
I think I have a picture that I took of that in 1964 at the Henry Ford Museum somewhere. Chris B., what are "shut lines"? Dave
1925 mostly original coupe.
Chris Barker
- First Name: Chris
- Last Name: Barker
Gaps around panels and doors
