Fuel Shutoff Valve
Tim Rogers
Last Name: Rogers
Fuel Shutoff Valve
Post by Tim Rogers » Sun Oct 25, 2020 4:37 pm
Need help! Can't remember which position is "OFF" on this style valve. Lever pointed at carb or pointed at fuel line?
Thanks!
Last Name: Strange
Re: Fuel Shutoff Valve
Post by CudaMan » Sun Oct 25, 2020 4:43 pm
Usually, with the valve installed on the car, the handle pointing towards the engine is OFF and the handle pointing towards the fuel line is ON. There is another way to verify it for sure:
Is it installed on the car? If yes, put a bucket under the carb and open the drain valve at the bottom of the carb bowl. Even if the fuel shutoff valve is closed, the carb bowl will likely still drain into the bucket for a bit before it stops. If the fuel shutoff is open, the carb will continue to drain until you shut the fuel shutoff valve or you drain the entire gas tank dry.
If the valve is not installed on the carb, just blow into one end and twist the valve handle, it will become obvious which way is closed.
dhosh
Last Name: Hoshield
* REQUIRED* Type and Year of Model Ts owned: '24 RPU (Raodster converted to Pickup)
Post by dhosh » Sun Oct 25, 2020 7:48 pm
For most of these, the lever is aligned with the direction of flow in the line, for 'on'. Flip it 90 degrees, so now it points across the flow, for 'off'.
'24 RPU
Petoskey, Mi
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Sun Oct 25, 2020 7:55 pm
Tim,
I agree with Mark and Dennis. It appears I have the exact same fuel cutoff.
On/open is pointed toward the fuel line. I attached a pic of it in the on/open position.
Off is pointed at the carb.
Darin
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Sun Oct 25, 2020 7:57 pm
Thanks guys. I don't know why but I wasn't sure after my last drive.
