Ac brakes
Jeepster47
First Name: Matthew
Last Name: Cooper
Ac brakes
Post by Jeepster47 » Fri Jan 22, 2021 10:00 am
I’d there anyone still making the ac brakes and linkage kits ?
Quickm007
First Name: Mario
Last Name: Brossard
Re: Ac brakes
Post by Quickm007 » Fri Jan 22, 2021 10:03 am
Sure Larry did. I have 2 sets from them. Work perfectly. Super Mario Bross and Chuck Norris approve! :lol:
AC Brake Larry.JPG (54.24 KiB) Viewed 7428 times
Super Mario Bross ;)
1911 Touring
1914 Speedster
Jeepster47
First Name: Matthew
Last Name: Cooper
Re: Ac brakes
Post by Jeepster47 » Fri Jan 22, 2021 10:07 am
Thank you, i don’t like the rockys that Snyder’s have since they don’t work in reverse and disc kits don’t look well on a 100 year old car. I hear these work well . Anyone still making the linkage set up ?
Re: Ac brakes
Post by Steve Jelf » Fri Jan 22, 2021 10:39 am
Rich Baughman. http://www.mtfca.com/discus/messages/59 ... 1468453589
Jeepster47
First Name: Matthew
Last Name: Cooper
Re: Ac brakes
Post by Jeepster47 » Fri Jan 22, 2021 10:41 am
Thank you !
Quickm007
First Name: Mario
Last Name: Brossard
Re: Ac brakes
Post by Quickm007 » Fri Jan 22, 2021 10:45 am
Linkage Made by Richard
His name is Richard Baughman
3771 Auburn Folsom Rd.
Loomis CA 95650
916-652-7827
He makes a very good product and will work with you if you need help.
1911 Touring
1914 Speedster
Quickm007
First Name: Mario
Last Name: Brossard
Re: Ac brakes
Post by Quickm007 » Fri Jan 22, 2021 10:47 am
Also he's email: richandbertie@gmail.com
1911 Touring
1914 Speedster
Jeepster47
First Name: Matthew
Last Name: Cooper
Re: Ac brakes
Post by Jeepster47 » Fri Jan 22, 2021 10:48 am
Perfect, thank you
Jeepster47
First Name: Matthew
Last Name: Cooper
Re: Ac brakes
Post by Jeepster47 » Sat Jan 23, 2021 11:04 am
Unfortunately Richard is not making linkage kits at this time. He says hopefully in the near future he will be able to start up again. Is there anyone else making linkage?
Re: Ac brakes
Post by Mark Gregush » Sat Jan 23, 2021 11:24 am
If you are handy and inventive, you can make your own cable setup like the originals.
First Name: craig
Last Name: leach
Re: Ac brakes
Post by Craig Leach » Sun Jan 24, 2021 10:34 am
John @ Model T Ranch makes a equalizer very simular to the rocky mountain one. I made my own equalize for the A-Cs on my speedster ( pull type instead of push) and used chebby E-brake cables so I had an adjustment for cable length. I took them off & made rods for them the only differance I found was the rods rattle and the cables didnt. Unfortuneatly I gave the cables away.
Craig
dmdeaton
First Name: Danny
Last Name: Deaton
Re: Ac brakes
Post by dmdeaton » Sun Jan 24, 2021 10:53 am
Does anyone have a picture of Richard’s linkage bolted to a frame? I like the looks of his crossbar but hard to picture where it would bolt to the frame.
Aussie16
First Name: Warwick
Last Name: Landy
Re: Ac brakes
Post by Aussie16 » Sun Jan 24, 2021 5:43 pm
http://www.mtfca.com/discus/messages/17 ... 1314393335
http://www.mtfca.com/discus/messages/599638/623576.html
some great previous posts on Ac brakes, and also fantastic original Ac brochure images on Google.
I think the original cable operation set up should serve you well.
dmdeaton
First Name: Danny
Last Name: Deaton
Re: Ac brakes
Post by dmdeaton » Mon Jan 25, 2021 3:37 pm
I like Richards setup and may try to recreate it. I have a ton of stuff in the way and if I can get those control rods outboard of the frame it would work out for me.
Re: Ac brakes
Post by Mark Gregush » Mon Jan 25, 2021 3:40 pm
Or just keep it simple and use cables like the ends of the levers on the brakes would be setup for. Look at Sunday swap meet on the classifieds page. The top item shown is the link between the cable pulley and transmission pedal.
dmdeaton
First Name: Danny
Last Name: Deaton
Re: Ac brakes
Post by dmdeaton » Mon Jan 25, 2021 5:19 pm
I have a aux transmission in the way of bolting that to the drive shaft
Re: Ac brakes
Post by Mark Gregush » Mon Jan 25, 2021 6:03 pm
I made something like this for my rocky Mtn but with a few changes could work. Instead of the 26/27 brake arms I just used flat plate for the cross bar;
http://www.mtfca.com/discus/messages/33 ... 1384711491
You could mount pulleys with a cover over them so the cable would stay in place on each end of the cross bar and would go around the transmission. If you have the newer style replacement AC's that use rods and clevices then just use them.
Re: Ac brakes
Post by Original Smith » Tue Jan 26, 2021 10:37 am
The best way is to do the job the way AC did it, not the way it's currently done with rods.
dmdeaton
First Name: Danny
Last Name: Deaton
Re: Ac brakes
Post by dmdeaton » Tue Jan 26, 2021 3:39 pm
You cannot use the stock ac setup with a aux tranny as the tranny is in the way of the cables can you? I haven’t dug into mine yet to mock-up but only looked at you all’s pictures.
