License plate restoration
Executive Director
Topic author - Posts: 6
- Last Name: Bumgarner
Looking for a license plate restoration shop.
John iaccino
- Last Name: Iaccino
Re: License plate restoration
After painting the background color, I took my plates to a Fast Signs store where they made the numbers out of black vinyl and put them on the plates for $10 per plate. Worth a try to see if they will do it for you.
Steve
A list of some of the better, they are members of the vintage plate group.
https://www.alpca.org/faq/restorers/
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Steve- I sent you a PM. Dan
Brent Mize
- First Name: Brent
- Last Name: Mize
- * REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Brian Mabry just did these for me.
Beautiful work.
It usually takes about 4 months.
https://finishyourplates.com/about-the-business
Brent
Beautiful work.
Brent
Erik Johnson
- First Name: Erik
- Last Name: Johnson
My father is a license plate collector.
When he restores a plate, he paints the background himself and has a professional sign painter and pin striper paint the numbers and letters.
For backgrounds that are not black, white or silver, he goes to an automotive paint supply and has a digital color match done by having them scan a good original plate from the same year for the sample and purchases the paint packed into rattle can.
NorthSouth
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up, 1924 PACO Bodied Speedster
I had these made from scratch by a local sign shop using my damaged original pair as a guide.
They are the same size just positioned one behind the other.
- Attachments
- 1915 CA License Plates
- 20200805_143428-2.jpg (104.66 KiB) Viewed 3614 times
Rich in Colorado
- Last Name: Carlson
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door 1923 Touring
I used Larry Scott a few times. I noticed he was on the list that Dan posted. Larry does have a "real" job so if you are looking for a two day turn, not going to happen. He is in Denver, but I mail my plates to him even though I'm only about 30 miles away. Reasonable. Priced on how much work he needs to do. I sand blast mine before sending, helps with the cost.
Before
After
I assume he does plates from all states
Good Luck Steve,
Before
After
Good Luck Steve,
Rich in Colorado
1922 Model T Center Door
1923 Model T Touring
1928 Model A Tudor
1956 Ford Thunderbird
1966 Ford F250 Camper Special
1928 Model A Tudor
Chris Haynes
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Just a heads up for guys in CA. Take your unrestored plates to the DMV to get them registered to your car. Why? Because they won't accept a restored plate.
Other states require them to be restored. Both requirements are supremely stupid. How can they tell the difference between an NOS plate and a properly restored one? They can't.
LikelySteve Jelf wrote: ↑Sat Mar 06, 2021 12:35 amHow can they tell the difference between an NOS plate and a properly restored one? They can't.
troutjohn
- Last Name: Trout
- * REQUIRED* Type and Year of Model Ts owned: 1923 runabout, 1913 touring
Larry Scott does great work. I have several plates done by him.
