ECCT GUI
Tom_Carnegie
Last Name: Carnegie
MTFCA Number: 14685
ECCT GUI
Post by Tom_Carnegie » Thu Jun 17, 2021 6:01 pm
Does anyone know how to make the ECCT software full on the screen. The right hand side is cut off, and the mouse will not expand it. I have tried different screen resolutions and that doesn't help.
paddy1998
Last Name: Delaney
* REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
MTFCA Number: 50356
Re: ECCT GUI
Post by paddy1998 » Thu Jun 17, 2021 7:38 pm
What version of Windows are you running?
Tom_Carnegie
Last Name: Carnegie
MTFCA Number: 14685
Re: ECCT GUI
Post by Tom_Carnegie » Thu Jun 17, 2021 7:45 pm
XP SP3
Won't let me post without 10 characters.
paddy1998
Last Name: Delaney
MTFCA Number: 50356
Re: ECCT GUI
Post by paddy1998 » Thu Jun 17, 2021 8:03 pm
Have you used it successfully on Windows XP before and this is a new problem? Or did you load it in XP and this is what it always does?
Tom_Carnegie
Last Name: Carnegie
MTFCA Number: 14685
Re: ECCT GUI
Post by Tom_Carnegie » Thu Jun 17, 2021 8:21 pm
"Have you used it successfully on Windows XP before and this is a new problem? Or did you load it in XP and this is what it always does?"
I can't say for sure. I have only ever used it on this computer, and not very often. It may have worked right at one time, but I rather think it has always been like this.
paddy1998
Last Name: Delaney
MTFCA Number: 50356
Re: ECCT GUI
Post by paddy1998 » Thu Jun 17, 2021 8:26 pm
I sent you an email. Give me a call.
Tom_Carnegie
Last Name: Carnegie
MTFCA Number: 14685
Re: ECCT GUI
Post by Tom_Carnegie » Thu Jun 17, 2021 9:22 pm
I do not have the ECCCCCT with me right now. May I call you tomorrow?
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Re: ECCT GUI
Post by DHort » Thu Jun 17, 2021 10:30 pm
You can always click on the box in the top right corner for a temporary fix.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
MTFCA Number: 50618
Re: ECCT GUI
Post by Jeepbone1 » Thu Jun 17, 2021 10:42 pm
I can’t comment on your issue specifically but when we bought ours, we bought an el cheapo windows 10 laptop from Walmart just to run the ECCT and it’s software. Then had to get a small USB disc drive to download the software. That took a lot of the headache away.
Brad
Tom_Carnegie
Last Name: Carnegie
MTFCA Number: 14685
Re: ECCT GUI
Post by Tom_Carnegie » Fri Jun 18, 2021 12:16 am
"You can always click on the box in the top right corner for a temporary fix."
Nope. Puffs it up full screen, but is still cut off on RH side.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Re: ECCT GUI
Post by Burger in Spokane » Fri Jun 18, 2021 2:40 am
Have you tried moving the computer screen to the right ? :roll:
JohnH
Last Name: Hunter
* REQUIRED* Type and Year of Model Ts owned: 1926 Geelong Tourer
Board Member Since: 2002
Re: ECCT GUI
Post by JohnH » Fri Jun 18, 2021 2:48 am
I experienced that only if the resolution was less than 1280 x 1024. I use it on Windows 2000, XP and 7. My Windows 2000 laptop won't allow that high of a resolution, but the cut-off GUI doesn't affect functionality. My XP and 7 PC's have higher resolution which shows everything.
Tom_Carnegie
Last Name: Carnegie
MTFCA Number: 14685
Re: ECCT GUI
Post by Tom_Carnegie » Fri Jun 18, 2021 11:29 am
"Have you tried moving the computer screen to the right ?"
Everything in Spokane is already as far to the right as possible. :)
Re: ECCT GUI
Post by TRDxB2 » Fri Jun 18, 2021 12:17 pm
Have you tried reducing the image size by holding the Ctrl key down and tapping the '-' (minus) sign key to make the displayed page smaller? To get back to normal use Ctrl and '+' (plus) sign to make things bigger.
Tom_Carnegie
Last Name: Carnegie
MTFCA Number: 14685
Re: ECCT GUI
Post by Tom_Carnegie » Fri Jun 18, 2021 2:08 pm
"Have you tried reducing the image size by holding the Ctrl key down and tapping the '-' (minus) sign key to make the displayed page smaller? To get back to normal use Ctrl and '+' (plus) sign to make things bigger."
Tried that. No change.
I have found a work-around. I set up a second (virtual) monitor and extend my desktop onto it.
Thanks for everyone's input.
MKossor
Last Name: Kossor
MTFCI Number: 22706
Re: ECCT GUI
Post by MKossor » Fri Jun 18, 2021 3:01 pm
JohnH has it right, the ECCT Advanced Features Software was developed for a 5∶4 aspect ratio screen resolution of 1280 x 1024. Older older monitors and laptops (prior to 2002) may have screen resolutions limited to 1024 x 768 or lower which will cut off the ECCT Graphical User Interface (GUI) as in Tom's post. 1280 x 960 should also work if you have that capability. Glad you found a solution with the MT500 quickly approaching ;)
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Re: ECCT GUI
Post by varmint » Fri Jun 18, 2021 4:26 pm
If your laptop has an external monitor port (probably VGA, maybe HDMI) then you can connect a monitor or perhaps your TV if it has a VGA or HDMI port. But you will need the appropriate data cable.
Vern (Vieux Carre)
