Seat spring size
Magnusw
First Name: Magnus
Last Name: Wiberg
Seat spring size
Post by Magnusw » Tue Jun 22, 2021 6:29 am
Hi,
can someone give me the precise measurements of the front and rear original Ford spring cushions and also for the front and rear backrest springs. What I need is the outer measurments, as I have problems to make the new Snyders upholstery kit parts fit, especially on the front cushion.
Kerry
Last Name: van Ekeren
Re: Seat spring size
Post by Kerry » Tue Jun 22, 2021 8:05 am
I'm sure to get an answer for you question, one would need to know year and body style.
Magnusw
First Name: Magnus
Last Name: Wiberg
Post by Magnusw » Tue Jun 22, 2021 8:44 am
You nare absolutely right! Of course, I need to give year and body style with my question! I just forgot!!
The Model T in my question is a 1919 US built Touring car.
Magnus
Post by Mark Gregush » Tue Jun 22, 2021 9:32 am
I was given the front seat section of a 1919 or 1920 touring. It looked like the upholstery had never been off. The back cushion was hung off the tack rail, there was a piece of upholstery card stock between it and the body, no other support. The bottom cushion is; 17-1/2" X 36-3/4" (44.45 X 93.345 CM). If you need the front seat back rest, I can get that later.
1920 Dodge touring
