Full Floating Rear End
1902Crest
First Name: mike
Last Name: west
* REQUIRED* Type and Year of Model Ts owned: one
Post by 1902Crest » Tue Jul 27, 2021 8:08 am
Ive read comments about Model T Full Floating Rear Ends. I have other antique cars that have full floating rear ends where as the if a axle breaks the wheel didnt pass you. All the bearings were outboard of the differential.... How is this accomplished on a model T? The reason I ask is I want to make a dummy axle using rear end T parts for a trailer. Ill use the backing plate castings and rivet a straight DOM piece of tubing in-between. I could then use these outboard bearings to control the wheels. All comments welcome! I don't want to use a welded up front axle. Thanks Mike
MTFCA Number: 51486
Re: Full Floating Rear End
Post by TXGOAT2 » Tue Jul 27, 2021 8:43 am
If you want a trailer axle that looks like a T and uses T wheels, you could probably use a gutted T housing and install modern trailer axle stubs or a full axle into the T housing, then modify the modern hubs to accept T wheels. Stub axle and hub assemblies and full axles in a variety of load ratings are available at Tractor Supply and elsewhere. These have typical modern type wheel bearings. It might be possible to cut a full axle in two or use two stub axles and install a left and right axle/hub/bearing assembly in the T housing without permanently altering the housing itself by fabricating some adapter pieces to secure the modern half axles or stub axles in the T housing.
1902Crest
First Name: mike
Last Name: west
Post by 1902Crest » Tue Jul 27, 2021 9:19 am
Pat, Thats a better idea than mine. Much better and most likely more cost effective. Thanks Mike
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Jul 27, 2021 1:02 pm
Most all safety hubs use a single row ball bearing. The radial load rating of these bearings is more than adequate to carry the weight of a Model T.
With that said, using a similar design without axles to resist the overturning moment that the bearing would see might not work out so well.
I like the idea of putting stub axles in the ends of a set of rear end housings if you want that look.
1902Crest
First Name: mike
Last Name: west
Post by 1902Crest » Tue Jul 27, 2021 3:16 pm
Great point made! Thanks
mike catlin
Last Name: Catlin
* REQUIRED* Type and Year of Model Ts owned: 1923 depot hack
MTFCA Number: 26310
Post by mike catlin » Tue Jul 27, 2021 8:14 pm
I have a model t trailer axel straight shaft use front wheels let me know your location
1902Crest
First Name: mike
Last Name: west
Post by 1902Crest » Tue Jul 27, 2021 8:45 pm
Livonia NY.
