Early crank pulley removal help
Topic author - Posts: 61
- First Name: Wilber
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1910 Model T Touring
- MTFCI Number: 22121
I'm trying to remove the busted crank pulley on my 1910 T, but I can't seem to get it far enough to remove it from the engine because the narrow engine snout won't allow it. There's got to be another way to get this off other than removing the pan. Any tips would be appreciated!
- Last Name: Hanlon
- MTFCA Number: 50191
Re: Early crank pulley removal help
Is it a stock pulley ?
I think the aluminum pulley, you do need to remove the pan.
Yep, it's stock.
Bill, it may be a stock pulley, but from a later car. Can you give us the diameter? I believe the correct size pulley can be removed with a narrow nosed pan in place.
Allan from down under
It will have to wait until tomorrow: heavy winds and rain drove me into the house.
Well I discovered the reason why I couldn't get the pulley off very easily: the left side of the engine pan nose was slightly bent in so the pulley kept stopping on the one rivet. So I had to grind the obstacle down enough to force the pulley off. It is 3" in diameter, but I'm not sure if it's an early or later style. I'd send a picture but I can't seem to get my smarty phone camera to take correct size pictures for this site!
3 Inch is the earlier size. You might need to find an old one which fits. Sometimes if not too worn, a thin shim between the pulley and crank will help. The aluminum pulley is best, however, it has a lip around the edge which would interfere with the installation. I think there might be one available without the lip. Chaffin's Garage part number 3963-ADJ That one is 3 inches without the lip.
Thanks Norm, I'll probably order the aluminum one without the edges since I had difficulty getting the old one off. Also, my old one has a large chunk missing on the inner hole so not usable.
Bill, an early one is worth saving. I have some black pipe which is a little bigger OD than the centre of the pulley. I bore out the old damaged centre to fit the pipe. Usually there is a radius left on the back of the pulley into which I run a full circle weld. The pipe is then machined back to length and bored to suit the crankshaft snout. If you drill the crank pin hole on one side and use another crankshaft hole as a guide to drill the other side, they are a good fix to a common problem.
Hope this helps.
Hope this helps.
