Front spring perches
John L
Last Name: Leffler
* REQUIRED* Type and Year of Model Ts owned: 1923 Coupe, 1927 Touring
MTFCA Number: 22526
Post by John L » Wed Oct 13, 2021 4:50 pm
I installing the front axle again after I had it straightened out .How do I identify a left from a right front spring perch? Is there a difference?
MTFCA Number: 14383
Re: Front spring perches
Post by speedytinc » Wed Oct 13, 2021 5:14 pm
There is a difference. When installed properly the axle rakes back around 6 degrees@ the top with the perch bushings horizontal.
MTFCA Number: 28924
Post by John kuehn » Wed Oct 13, 2021 5:30 pm
Go to Lang’s web site and take a look at the right and left spring perches. That will show you the angle of the left and right perches. You can use the pics as a guide.
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
MTFCA Number: 49752
Post by KBurket » Wed Oct 13, 2021 5:41 pm
The boss on the elbow of the perch goes to the rear.
http://www.mtfca.com/discus/messages/82 ... 1536671439
* REQUIRED* Type and Year of Model Ts owned: '23 cutoff, '25 touring, '27 touring
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Wed Oct 13, 2021 8:54 pm
This illustration shows the boss lug, with is used for lathe turning, that boss must be to the rear of the axle.
Altair
First Name: David
Last Name: Menzies
MTFCA Number: 27825
Board Member Since: 2012
Post by Altair » Tue Oct 19, 2021 2:09 am
The left front perch is odd numbered 3819 and right is even 3818. On a Model T all odd numbers are left and even numbers are right where there is a left and right part.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Oct 19, 2021 1:51 pm
I'll take another whack at this dead horse. :)
The arrow points to the part that goes toward the rear of the car.
