'26-'27 Radiator Fan Lube??
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Post by Professor Fate » Sat Apr 09, 2022 9:05 pm
Can you or how do you lube the bearings in the hub of a '26-'27 fan?
Not seeing the screw to lube earlier ones on "improved" T.
Thanks in advance.
________________
**FATE**
Last Name: Patrick
Re: '26-'27 Radiator Fan Lube??
Post by jiminbartow » Sat Apr 09, 2022 11:09 pm
Unscrew the fan hub set screw just behind the fan and fill the reservoir with engine oil. The oil flows through a tunnel through the center of the shaft and comes out into the void between the front and rear bushings. Jim Patrick
Post by DanTreace » Sun Apr 10, 2022 5:28 am
Have found heavy oil like 600w gear oil better as less can sling past the felt seal, clings well to the brass bushing surface too.
Post by Allan » Sun Apr 10, 2022 7:02 am
Chain bar oil is rather clingy too.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sun Apr 10, 2022 7:16 am
As everyone has already stated, oil. But for oil to stay in the hub you need a good felt seal at the back and a good sealing paper gasket at the fan blade, and your bushings cannot be all worn out and sloppy.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Apr 10, 2022 10:48 am
That’s a nice drawing Jim! Very detailed 👍
Professor Fate
Last Name: S
Post by Professor Fate » Sun Apr 10, 2022 1:48 pm
Thank you!
-Dan
________________
**FATE**
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Sun Apr 10, 2022 8:46 pm
My earlier post on this subject disappeared for some reason... but I agree with all of the above responses except you may have
a modern sealed bearing upgraded Fan Hub? I would remove and service your Fan / Hub. Make sure the oil feed holes are clear
and all parts are serviceable. It will give you peace if mind to know the style you have and that it’s well lubed, serviceable
and give you trouble free service for many years!
Cheers Alan
Western Australia
Last Name: Patrick
Post by jiminbartow » Sun Apr 10, 2022 10:08 pm
Thank you Bryant. I drew it ten years ago when I had my fan assembly apart installing new bushings and seals. Regarding the oil viscosity, the most important thing is to find a happy medium. The oil needs to be thin enough to flow through the shaft tube but thick enough to not be slung out. Too thick and it will not be able to find its’ way through the shaft to the void between the bushings. Jim Patrick.
Professor Fate
Last Name: S
Post by Professor Fate » Sun Apr 10, 2022 11:35 pm
I looked fort the oil screw and couldn't find it. Might be under some paint.
________________
**FATE**
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Mon Apr 11, 2022 6:28 am
Is it a problem to lube the bearings with grease ?
Toon
Last Name: Humble
Post by Humblej » Mon Apr 11, 2022 6:56 am
Grease is not a good lube for a bushing turning at a high speed. The fan pulley is a little smaller than the crankshaft pulley, so the fan is turning faster than the crankshaft, that's too fast for grease as a lube for a bushing in my opinion.
Chuck Regan
First Name: Chuck
Last Name: Regan
Post by Chuck Regan » Mon Apr 11, 2022 11:45 am
Dan - here is photo of oil screw on my ‘26.
Post by Original Smith » Mon Apr 11, 2022 12:10 pm
I haven't seen any documentation from Ford, on what they used back then, but I am using SAE 140 in mine, and it works. It's a good idea to check it from time to time, and it does leak out over a period of time. Putting in a modern bearing is a waste of time. Be sure to use the proper felt seal and retainer like Ford says, and you will have no regrets.
Professor Fate
Last Name: S
Post by Professor Fate » Mon Apr 11, 2022 3:20 pm
Thank you for the picture. I'll check later today, but I think the brass screw on mine is under some paint. Might have to clean things up a bit.
But thanks again.
--Dan
________________
**FATE**
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Mon Apr 11, 2022 7:42 pm
After owning my T for nearly 20yrs, I had no idea there was such a seal. There wasn't one there when I got the car. Just goes to show there's still more to learn. Sure enough, the felt does exist https://www.modeltford.com/item/3983.aspx
Until now I just accepted the fan hub was a 'total loss' oiling system and put up with the mess. And, I was about to order a modern sealed bearing to stop the oil leaking...
Thanks for mentioning this!
Professor Fate
Last Name: S
Post by Professor Fate » Tue Apr 12, 2022 8:50 pm
Thanks for that pic Chuck.
I had to do a little exploring thru multiple layers of paint and gunk to find mine on my '26 project.
Road testing of car weeks away now..... can't wait.
I built it from a very clean frame, a rusty rolling chassis, and a pile of parts.
I've had a great time just getting to this point. Fun!!!
________________
**FATE**
Chuck Regan
First Name: Chuck
Last Name: Regan
Post by Chuck Regan » Tue Apr 12, 2022 9:21 pm
Dan - glad the picture helped - holler if you need anything else. Post a pic of your ‘26 when she’s on the road.
Professor Fate
Last Name: S
Post by Professor Fate » Tue Apr 12, 2022 9:27 pm
Half windshield and hood to be installed shortly. Speedster style! No fenders 4 me......😁
________________
**FATE**
Professor Fate
Last Name: S
Post by Professor Fate » Tue Apr 12, 2022 9:31 pm
Can't wait to go running with the pack in '22!
________________
**FATE**
