What parts of a 1926-27 T are marked Canadian?
Matt in California
Topic author - Posts: 829
- First Name: Matt
- Last Name: G
I recently acquired a Canadian chassis for parts. Thus far I have found the front axel, engine block, head and transmission hogs head. I am passing on some of the Made in Canada parts to a fellow member.
What parts have Canadian markings?
Thanks!
Matt
Thanks!
Matt
Re: What parts of a 1926-27 T are marked Canadian?
I have seen it on the radiator shell.
Intake & exhaust manifolds.
Altair
- First Name: David
- Last Name: Menzies
- Board Member Since: 2012
It is also on the Canadian Top Bow Saddles and connecting rods.
Matt in California
- First Name: Matt
- Last Name: G
How about rear axle?
Was every part made in Canada? And just some are clearly marked?
Front hubs also had "Made In Canada".
Kelsey wheel felloes and rims will also be stamped Windsor Ont. The list goes on. The reason was to facilitate exports to British Empire countries. Canada being part of the empire meant that these cars when imported into Australia, New Zealand etc did so at favourable rates of duty. Ford, Canada was set up for precisely this purpose.
DJPeterson
- First Name: Dale
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1916 Roadster, 1925 Roadster PU, 1926 Canadian Fordor, 1927 Speedster
Radiator shell
Head
Block
Running boards
Door hinges on my 26 Fordor are stamped "Stanley made in Canada"
Head
Block
Running boards
