Exhaust rings for different car
Linus Tremaine
First Name: linus
Last Name: tremaine
* REQUIRED* Type and Year of Model Ts owned: I do not have a model T. But I like them. I Have a 1930 Lincoln.
Post by Linus Tremaine » Sun May 22, 2022 5:05 pm
I have a 1921 studebaker and it uses the spring steel rings between the block and the manifolds. I found that some of mine were missing and I wonder if there is a general source that makes these for model T and other cars. Does anyone know where I might find some?
Re: Exhaust rings for different car
Post by speedytinc » Sun May 22, 2022 5:14 pm
The rings are not spring steel. They are a strip of soft sheet metal of the proper length & width that when bent into a circle fit motor & manifold recesses. The better rings are made of tubing machined to the proper dimensions. You can make your own of either type easily yourself. If not, a machine shop could do the job cutting some tubing rings.
Post by Rich Eagle » Sun May 22, 2022 5:28 pm
I just cut them from sheet. John is right. If you had the right size tubing that would be better.
Linus Tremaine
First Name: linus
Last Name: tremaine
Post by Linus Tremaine » Sun May 22, 2022 6:16 pm
Thanks guys. I will make them.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun May 22, 2022 6:56 pm
Or make them from a short piece of exhaust tubing/pipe.
Hank
Post by Allan » Sun May 22, 2022 7:44 pm
Continuous rings cut from exhaust pipe tubing are better. Thew will not deform like the strip type nor give grief when fitting the manifold. Also, if you do not have a source for gasket rings, they can be cut from any exhaust gasket material. When I built the header for my speedster, I cut six rings, already formed, from a gasket to suit a modern 6 cylinder car. Just see your parts house to find one for your purposes.
Hope this helps.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun May 22, 2022 7:53 pm
Are the rings larger maybe model A will fit.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon May 23, 2022 12:59 pm
Restoration Supply has the copper crush rings in various sizes- see page 45 of their catalog.
https://restorationstuff.com/
