Anyone Stamping Firewall Data Plates?
Tbird
Last Name: Bird
Post by Tbird » Thu Nov 17, 2022 11:09 pm
R.V Anderson (R.I.P) had a set of numbers made up to stamp the data plates. https://www.mtfca.com/discus/messages/ ... 24665.html
I had a radiator tag stamped by him but never got my dash plate stamped… any one have any idea what became of his numbers to stamp the plates?
First Name: Keith
Last Name: Townsend
Re: Anyone Stamping Firewall Data Plates?
Post by KWTownsend » Fri Nov 18, 2022 10:35 am
Mike,
You could probably find an engraver shop that has an olde time font. I have seen both the fancy font as well as the plain font like on these 1/8" stamps at Harbor Freight.
https://www.harborfreight.com/18-in-ste ... 63676.html
Keith
Post by TRDxB2 » Fri Nov 18, 2022 4:16 pm
Possible matching font JMH Arkham
But the others are close enough too
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Nov 20, 2022 8:59 am
Someplace and sometime ago, I saw a photo of the device used to stamp the engine numbers.
The handle looked like the handle used to lift the round lids off a cook stove to add more wood.
The other difference was a rectangular slot that would hold 8 3/8th inch square number stamps.
There was a thumb screw on the end that would lock them in place once the correct number was selected.
I have never been able to find that photo again.
The handle look
ed like this handle.
Post by TRDxB2 » Sun Nov 20, 2022 12:36 pm
Found this while searching for the stamp holder https://www.mtfca.com/discus/messages/3 ... 1377689801
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Mon Nov 21, 2022 7:49 am
Here is a plate that was stamped by RV.
Tbird
Last Name: Bird
Post by Tbird » Mon Nov 21, 2022 8:14 am
I'm curious to know if someone bought his set of stamps after he passed away?
Post by Jerry VanOoteghem » Mon Nov 21, 2022 12:31 pm
Looks like these folks could help you out...
https://www.steelstamps.com/custom-font ... p-set.html
