Model T accessory??
les_rens
Topic author - Posts: 23
- First Name: Les
- Last Name: Rens
- * REQUIRED* Type and Year of Model Ts owned: 26 open, 25 tudor, many parts cars.
Model T accessory??
This came in a parts lot of Model T stuff. Is it some sort of optional part or accessory??
Ruxstel24
- Last Name: Hanlon
Re: Model T accessory??
That's an early Sirius XM antenna...
- Last Name: House
Ha ! Dave, you’re too funny....All seriousness aside - It’s a steering stabilizer. The bottom part between the 2 spring circles (on the runningboard) fastened to the rod bolted to the 2 spindle arms and the 2 “”antenna”” simply were forced onto the backside of the front axle.
- First Name: Henry
- Last Name: Lee
LMAO Dave!!!
It's a groove maker. It digs grooves in your tie rod.
KeithG
- First Name: Keith
- Last Name: Gumbinger
Steve is absolutely correct. This is a cheap temporary fix for a loose front end. These were often used during the Depression when people often couldn't afford a good front end rebuild.
Keith
Keith
FundyTides
- First Name: David
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Absolutely right Steve. These work very well as evidenced by the very precise grooves cut into the tie rod on our 26 Touring when we bought it.
DLodge
- First Name: Dick
- Last Name: Lodge
C'mon, Dave, be sirius!
