Headlight rims
Harvey Bergstrom
First Name: Harvey
Last Name: Bergstrom
Headlight rims
Post by Harvey Bergstrom » Thu Dec 14, 2023 5:57 am
I installed new headlight rims on my model T in the restoration process. Now I want to remove them and can’t get them off. I know you are supposed push in and rotate to the left approx. an inch and then they should come off, however they will not budge. Has anyone else had this problem?
Thank you for any replies!
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Headlight rims
Post by Humblej » Thu Dec 14, 2023 7:10 am
Yes it is a problem to remove a headlight rim. In theory you push in and rotate and they are off, realistically it takes 4 hands, one to push and rotate at each rivet. I have had success with a helper so we have 4 hands pushing and turning. The Ford Service Bulletins have a drawing to make a tool that clamps down on the entire headlight rim and I can attest that it works like a charm. I fought loosing battles with headlight rims for 50 years never wanting to take the time to make the tool, I broke down and finally made one recently and love it.
Link to the tool thread
https://www.mtfca.com/phpBB3/viewtopic. ... 89#p296589
jiminbartow
Last Name: Patrick
Re: Headlight rims
Post by jiminbartow » Thu Dec 14, 2023 7:55 am
Mark Nunn
Last Name: Nunn
Re: Headlight rims
Post by Mark Nunn » Thu Dec 14, 2023 8:19 am
After you get the rims off, grind down the pins to make them shorter. The repro rims have pins that are too long making removal difficult. I, and many others, have shortened pins with success. The real trick is getting the rims off to do the job.
Re: Headlight rims
Post by DanTreace » Thu Dec 14, 2023 3:17 pm
Here are the dimensions of the original tang of the 4 rivets on the headlamp rim. Use for reference.
jiminbartow
Last Name: Patrick
Re: Headlight rims
Post by jiminbartow » Thu Dec 14, 2023 8:31 pm
Many folks forget to bend the rim tangs down over the edge of the lens, allowing the lens to be loose and rattle against the lens. I know, because I’m one who forgot. Bending the tangs down over the edge of the lens attaches the lens to the rim. Jim Patrick
John Codman
Last Name: Codman
Re: Headlight rims
Post by John Codman » Fri Dec 15, 2023 9:42 am
My headlight rims were in bad shape. I purchased a pair of repros from one of our suppliers. I could not get them to fully install properly. I then sent the originals out to be re-Nickle plated. When I got them back, they slid into place perfectly. Conclusion: The repros are different in some way from the originals.
Harvey Bergstrom
First Name: Harvey
Re: Headlight rims
Post by Harvey Bergstrom » Sun Dec 17, 2023 9:16 am
Thank you all for your responses on my headlight rim dilemma. I like John’s idea of getting the originals replated and putting them back on. At least they fit well and go on & off as they should.
springerpete
First Name: Bill
Last Name: Alexander
* REQUIRED* Type and Year of Model Ts owned: 1925 roadster pick up
Re: Headlight rims
Post by springerpete » Sat Dec 23, 2023 3:08 pm
I finally took my belt off from my jeans, wrapped around the rim and put it thru the buckle without the tongue. Stretched it out hard around the rim and pushed the rim in while trying to rotate the rim. Rim came off with no problem
