Find the 'Ford'
First Name: Austin
Last Name: Farmer
Find the 'Ford'
Post by 1925 Touring » Thu Jul 10, 2025 1:46 pm
It's always fun, to me, when working on the T, to look for where there is 'Ford' stamped into each and every part. I thought this would be a fun thread to have, posting pictures of all the 'ford's on our Fords. :)
Here's one, on a rear axle shaft.
Where's the ford on your car?
Re: Find the 'Ford'
Post by speedytinc » Thu Jul 10, 2025 1:59 pm
Thats a fine idea.
However, in a semi related vain, you would do well to get rid of those solid repop hyatt replacements.
Slightly worn hyatt's would serve you better. Solids are hard on axle shafts.
Look for past discussions on the topic.
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Re: Find the 'Ford'
Post by FundyTides » Thu Jul 10, 2025 2:31 pm
Great idea! There could be a subcategory of "Made in Canada" stampings. Here's one on a "slightly used" 26-27 runningboard. If you think this should be a seperate thread, that's ok too.
First Name: Austin
Last Name: Farmer
Re: Find the 'Ford'
Post by 1925 Touring » Thu Jul 10, 2025 3:42 pm
The more the merrier :D
Anything T related with Ford on it.
It's amazing all the places it can be found.
Daisy Mae
First Name: Kurt
Last Name: Andersson
Re: Find the 'Ford'
Post by Daisy Mae » Thu Jul 10, 2025 3:49 pm
How about Dodge?
FundyTides
First Name: David
Last Name: Wilson
Re: Find the 'Ford'
Post by FundyTides » Thu Jul 10, 2025 6:24 pm
Here's my 27 motor with Ford Made in Canada on it and a 27 front hub showing Canada on the tag. I'll have took but I think Ford is also stamped on the hub
Re: Find the 'Ford'
Post by TRDxB2 » Fri Jul 11, 2025 2:48 pm
Door latch
Spring Clip & Bar, Ball cap, Spindle bushings, tie rod yoke (click on photo to zoom in)
Re: Find the 'Ford'
Post by Steve Jelf » Fri Jul 11, 2025 4:25 pm
CDooREDW
First Name: Ron
Last Name: Wenzel
* REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: Find the 'Ford'
Post by CDooREDW » Fri Jul 11, 2025 9:26 pm
First Name: Austin
Last Name: Farmer
Re: Find the 'Ford'
Post by 1925 Touring » Sat Jul 12, 2025 7:59 pm
Today's Ford
MarkS
Last Name: Sumner
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Model T Touring
Re: Find the 'Ford'
Post by MarkS » Mon Jul 14, 2025 1:46 pm
The OP didn’t specify that the “Ford” logo needed to be an original part, so here is my submission.
I added an electric stop light to my ‘15 touring, which meant i needed a stop light switch. The switch being near the trans inspection cover, I was worried that a tool might inadvertently short out on the exposed wire terminals when working down there, so I 3D printed a switch cover (black, of course) and decided it needed an “authentic” Ford logo.
Re: Find the 'Ford'
Post by Original Smith » Mon Jul 14, 2025 3:03 pm
In this hobby, I got the name Original Smith because of that. I was in my early 20's and was always looking for NOS parts with the Ford script. There was a junk yard in Gardena, that had bins of parts that came from an old store in Los Angeles called HENRY'S and LIZZIES. That is where I used to find a lot of those parts. I used to work there on weekends for free, and was rewarded with lots of those NOS parts for my time.
love2T's
First Name: T
Last Name: Gates
Re: Find the 'Ford'
Post by love2T's » Mon Jul 14, 2025 8:28 pm
Here's some from Keith Gumbinger.
Bryant
First Name: Bryant
Last Name: Shafer
Re: Find the 'Ford'
Post by Bryant » Mon Jul 14, 2025 9:34 pm
Hogshead. One of the bigger ones
Bryant
KeithG
First Name: Keith
Last Name: Gumbinger
Re: Find the 'Ford'
Post by KeithG » Mon Jul 14, 2025 10:22 pm
I haven't yet mastered posting pictures on the Forum so a friend posted these pictures for me just a few posts above.
The first one is a crankshaft with the script and part number shown and towards the bottom is a logo with a T over a W, which stands for Transue Williams, a common Ford parts supplier. You will note that this is a broken crankshaft and that it is a "diamond" shape between the rods. These crankshafts are notorious for breaking for two reasons: The diamond shape is weak and Transue Williams cranks are noted for poor quality. I will never use another one of them.
The second picture shows an original babbitt driveshaft bearing, the one that goes just behind the U Joint. Also shown in red primer is a round fellow wheel joining plate. You very rarely see these. I found this one at a swap meet and later noticed that I had them on both rear wheels on my '14 Touring. Quite rare. The last item is a castle nut from the rear spring perch on a TT truck. Why would Ford put script on an ordinary castle nut? Who knows, but I have found several others like this one.
Keith
Last Name: Hatch
Re: Find the 'Ford'
Post by Dan Hatch » Fri Jul 18, 2025 10:37 am
Here is an nos tie rod bolt.
First Name: Austin
Last Name: Farmer
Re: Find the 'Ford'
Post by 1925 Touring » Fri Jul 18, 2025 8:13 pm
Rear axle housing
