Gas shut off valve
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Gas shut off valve
Post by Dennis_Brown » Wed Jul 30, 2025 2:15 pm
The handle on a potato gas shut off valve is broken off and gone. Has anyone tried to attach some type of handle to one?
Also I can not remember what was suggested on how to remove the brass valve.
First Name: john
Last Name: karvaly
Re: Gas shut off valve
Post by speedytinc » Wed Jul 30, 2025 2:36 pm
To remove: remove the cotter pin, washer & spring.
Make a hollow punch that only contacts the base of the valve below the stud/post.
Post by RajoRacer » Wed Jul 30, 2025 3:15 pm
AND - it helps if someone else can hold onto the sediment bulb !
Post by TRDxB2 » Wed Jul 30, 2025 5:32 pm
Please confirm the year shut off valve you are referencing. Your profile says you have a 1926 Roadster pickup. and that valve is different than the earlier ones that are known for handles to brake off
If its the earlier style save yourself the trouble and remove the sediment bulb. The don't sell replacement lever arms.
Regardless of which you have...
To remove the sediment bulb you need to be a bit gentle. Don't try to remove it with a long handled wrench you may damage the fitting on the tank. Put a wrench on it an tap the wrench, acts like an impact wrench to break it loose.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Jul 30, 2025 6:35 pm
Simple..., Take a piece of round brass stock and silver solder it on. Shape to your desire!
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Wed Jul 30, 2025 6:46 pm
You could probably make a handle once you get it off. It’s just a larger version of the pre-1915 Kingston petcock handle. I made the ball part and tapped it 4-40 and used threaded rod to attach it to the part that runs through the body. I made the handle and left a nib that I inserted into a hole I drilled in the ball then I soldered it all. Just have to do it on a larger scale.
Post by DanTreace » Wed Jul 30, 2025 9:17 pm
Since the handle is busted off, likely the valve is really stuck in the bulb. Plus the large brass nut has to come off anyway to clean or replace the filter screen soldered to the nut.
So best is to heat the iron bulb around the lever and nut, you can get the iron really hot to near dull red and then cool in a freezer placing on a wood board. When cooled the brass parts shrink and are easy to remove. Careful to punch out the lever part using a hollow punch as noted, or the end that holds the coil spring and washer with cotter will be wrecked.
You may be able to find a donor sediment bulb to obtain another valve with intact handle.
heat with torch then cool.jpg (59.2 KiB) Viewed 305 times
hollow punch.jpg (18.51 KiB) Viewed 305 times
Messed up valve end
Post by RajoRacer » Wed Jul 30, 2025 9:59 pm
FYI - not all valve/handle combinations are compatible with all sediment bulbs - I have found several different lengths of tapers.
