Are Kevlar bands all the same?
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sat Aug 16, 2025 11:12 pm
I need to buy some Kevlar bands. Are they all the same or are some better than others?
Re: Are Kevlar bands all the same?
Post by TXGOAT2 » Sun Aug 17, 2025 8:52 am
Kevlar is a specific product. There could be differences in the actual construction of the bands. My car has Kevlar bands, and they work very well and have not required adjustment after many miles over several years. I don't know who supplied them.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Aug 17, 2025 11:14 am
Kevlar is a brand name for the material the bands are made from. As you say, different companies weave the bands, which means the are likely variations in the final product. I am just wondering if there is a meaningful difference between the available bands. I have Kevlar bands in my 22 but I don’t know where they came from.
Post by TRDxB2 » Sun Aug 17, 2025 11:42 am
Short answer No. Various issues in the past with different manufacturers of bands. Now its up to which supplier provided good ones this year.
viewtopic.php?f=2&t=48665
https://www.mtfca.com/discus/messages/5 ... 1481656609
viewtopic.php?f=2&p=198477&t=25848
https://www.fordmodelt.net/transmission.htm
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Aug 17, 2025 12:47 pm
They are all yellow, as the manufacturing process leaves them that color.
To quote Will Rogers, who once said he never met a man he didn't like, I never found a Kevlar band that did not work fine and last a long time.
The real secret of success is to keep your feet off all the pedals and avoid any overheat problem.
Post by Wayne Sheldon » Sun Aug 17, 2025 6:03 pm
When Kevlar bands were first being used for model Ts, there were a few tries made at getting a balance between a cushioning effect and harsh realities. Some of the earlier efforts were too harsh. However, I "think" most of those issues got worked out some time ago. There was also a change in manufacturer a few years ago, I haven't tried any new ones since, but haven't heard anything bad about them since.
As far as the cracking of drums goes, I have always suspected that a lot of the problems were due to heavy-footed use of the bands. I knew several people that often said they had Kevlar bands and they were gonna use 'em HARD! They were usually the ones that later broke drums.
Personally, I like good cotton bands, and got a lot of miles out of them. However, since good reliable cotton linings are tough to get, I have used Kevlar in a few different Ts. I drive with Kevlar just like I did with cotton. Sometimes, in a few different Ts, I have used Kevlar on the brake, and cotton for low and reverse. Anymore, I am not sure what is in there. But I drive them all as if they were cotton.
Post by Allan » Mon Aug 18, 2025 12:06 am
Th first ones I used were supplied by the Custom Friction Company. These were not woven bands. Rather the kevlar was included in a lining material bonded to a fabric backing. They were difficult to rivet in place because the head of the rivets had to be countersunk into the wear surface, without getting into the backing material. These disappeared from the market when they went to a synthetic backing material which collapsed under the heat generated in operation.
The first woven ones, and probably the best I have used, were from Steve Connif.
Since then, I have used Wearever brand as sold by the vendors. I have seen some which appear a little thinner, and I avoid these.
FWIW Allan from down under.
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Post by Dodge » Tue Aug 19, 2025 12:26 am
I've been using Rocky Mountain Machine Kevlar bands. I've had them in 3 cars for 20yrs and they've ony been adjusted a handful of times.
My 2 cents.
I can't tell you if their all the same or not.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Tue Aug 19, 2025 8:05 am
There is two types I know of one is a loose knitting and the other is tight and hard to get an aw through those are the best, the loose ones will make fuzz through the engine.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Aug 19, 2025 8:32 pm
Steve Conniff =
Rocky Mountain Machine Co.
15931 Lake Mist Dr.
Monument, CO 80132
Phone 303-905-4605
