My 24 TT project (Hello all!)
Maineiac
First Name: Michael
Last Name: Whalley
* REQUIRED* Type and Year of Model Ts owned: A 1924 TT project, that started as a stripped chassis.
Post by Maineiac » Mon Nov 10, 2025 5:17 pm
Hello all! New member here, working on rebuilding a 24-25(?) TT I procured up here in Maine, and have been slowly piecing it together ever since.
So far, the old girls been pretty cooperative, and has shown no issues in the course of my inspection and repairs (save for the radiator and wheels). The engine has good compression on all four cylinders, and the starter kicked right up when I wired in the battery (Finding the battery holder straps was a real test).
The hood has the original business attire, and luckily, I found a replacement hood, as I don't plan on incorporating the original writing.
Found the cab cowl locally under a bush in someone's backyard, for a song, haha!
Anyhow, here's to further smooth sailing!
rwephill
Last Name: Evans
* REQUIRED* Type and Year of Model Ts owned: 1925 TT C-Cab
Re: My 24 TT project (Hello all!)
Post by rwephill » Mon Nov 10, 2025 6:15 pm
I just finished a '25 TT in October. Let me know if you have any questions, need any comparison pics, measurements, etc. I don't have all the answers, but I learned a lot getting mine back on the road. Picture is at a late October cruise night in Pleasant Hill, MO. That was its first journey out of my driveway and yard. My best to you on your restoration.
“You don’t have to go fast… you just have to go.”
Post by TXGOAT2 » Mon Nov 10, 2025 6:18 pm
I like the C-cabs with an express bed.
Daisy Mae
First Name: Kurt
Last Name: Andersson
Post by Daisy Mae » Mon Nov 10, 2025 6:24 pm
Very nice! My first T was a '25 Closed Cab TT.
I notice yours has a Ruckstell, nice! All torque & no speed LOL. You can literaly crawl in a parade. Do you know what ratio you have, 5:1/7:1?
Welcome!
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Mon Nov 10, 2025 6:34 pm
Welcome!
Thanks for the welcome!
I have done precisely nothing with the rear end, save for checking (and adding) oil levels to make sure it wasn't rusty inside. I can only speculate on the ratio.
Frankly, I'm looking into modifying a car diff and pumpkin to attach to the TT driveshaft and axles to attain something resembling the neighborhood speed limit! Since the old gal isn't going to be hauling a ton of rocks anytime soon, the torque won't be missed.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Mon Nov 10, 2025 6:45 pm
That's a beaut! I'm planning on building it in a fashion similar to this one, with a canvas top option and semi open cab. An important feature, being that it will *just* clear the garage door! :P
I'll certainly be posting questions on the forum as oddities arise, I've already found and corrected a few!
Safe travels!
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Mon Nov 10, 2025 6:51 pm
Just don't junk the Ruckstell, those for TT's are not easy to come by.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Mon Nov 10, 2025 6:55 pm
Not a worry, it'll get a good cleaning and greasing before going into cold storage. I'm loathe to discard anything casually that still has some use.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Mon Nov 10, 2025 7:56 pm
Hello Michael,
Welcome to the club. Love the TTs. I have a '25 TT and will answer questions. Good Luck.
FOR TXGOAT2:
1925 C-cab with Express bed.
Post by RajoRacer » Mon Nov 10, 2025 8:49 pm
Welcome to the madness ! Here's mine - Gramps bought it new in Seattle in '24. Use to take it camping with our 2 daughters when they were small.
grandpa's truck0001.jpg (27.44 KiB) Viewed 2003 times
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Nov 11, 2025 4:03 am
Welcome to the hobby~! Glad to see another TT getting some love.
Mine has a Ruckstell and an overdrive - can get her up to about 45mph but more comfortable at 30 mph.
The thing is, the combination of overdrive and Ruckstell gives some good combined gear ratios when the Ruckstell is engaged (underdrive) and over drive high is selected, especially when I am carrying a load, so don't write off the Ruckstell ! It also gives me 8 forward gears that sound great when you work through them, even if you are swinging levers like a madman :-)
Check out the drawings in the Gallery section where Martynn has put up some useful TT rear end exploded diagrams.
P1010899 (Mobile).JPG (50.4 KiB) Viewed 1944 times
Post by Jerry VanOoteghem » Tue Nov 11, 2025 6:29 am
No need to get rid of the Ruckstell. Yes, it allows you to go really slow, but only when it's engaged. Otherwise, it will drive like a normal TT.
Hap_Tucker
First Name: Hap
Last Name: Tucker
Post by Hap_Tucker » Tue Nov 11, 2025 7:15 am
Michael,
Great looking start on a TT! Suggest you look into how close a local Model T Ford club is. See the links at:
https://www.mtfca.com/chapters/#me
and also
https://modelt.org/chapter-directory
Sometimes depending on how close you are to another state the one in the nearby state may be closer. They along with the forum can be a great help with answering questions. Many times if you can look at one that is assembled it makes it easier to see how you can assemble yours.
Best of luck!
Hap l915 cut off
Post by TXGOAT2 » Tue Nov 11, 2025 8:54 am
A KC Warford + the Ruxtell will give you all the speed(s) you'd want in a TT, and a gear for most any situation.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Tue Nov 11, 2025 10:26 am
I was under the impression that the worm gear would be the limiting factor when it came to speed? An accessory overdrive wouldn't remove that particular bottleneck, because it's on the wrong side of the equation?
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Tue Nov 11, 2025 10:29 am
Michael,
and also
Best of luck!
Hap l915 cut off
Canada is technically closer to me than the local chapter, haha! I'm enrolled with the Downeast Chapter, and have met with several members. One of whom was generous enough to loan me his wheel spoke press to rebuild my front wheels.
I've been meaning to stop by the local land transport museum (Coles, it's quite impressive) and ask for the chance to take photos of their preserved TT.
Post by Jerry VanOoteghem » Tue Nov 11, 2025 10:31 am
The accessory overdrive is exactly what's needed. It allows that worm to spin much faster, hence, more speed down the road. Zoom zoom!
Post by TXGOAT2 » Tue Nov 11, 2025 11:30 am
Heat in the third member could be a problem if you drove the truck fast for long distances. Modern, lighter bodied lubricants would probably reduce heat buildup. But the speed limiting factor with a TT on level ground is the final drive ratio of around 7:1. The stock T engine runs best under 1800 RPM, which is 25 MPH or less in a TT. An auxiliary overdrive gear will allow higher speeds, but a stock T engine will lack power to push a TT with typical bodywork much over 35 MPH, maybe 40 + under good conditions. Adding a good high compression head and modern pistons and rings can get you 40-45 MPH under most conditions. The aerodynamic drag is very high in a TT, and it increases very rapidly as speed increases.
OTR trucks have many gears to choose from for a reason. The stock TT truck, with only two ratio options, is severely limited as to road speed. I don't know how much power it would take to move a TT truck 50 MPH on level ground on a calm day, but I'd guess it would be 30 HP or more. Probably more, and certainly more to maintain 50 MPH into headwinds or up hills or both.
Post by Norman Kling » Tue Nov 11, 2025 11:36 am
Looking good. How's the weather? Can you still tour this time of year? I live in the San Diego area so we can tour just about any month of the year.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Tue Nov 11, 2025 11:50 am
It's actively snowing at the moment, touring is strictly limited to those who have track conversion kits for their Ts!
mtntee20
Last Name: Miller
Post by mtntee20 » Tue Nov 11, 2025 12:13 pm
I will add my vote for a KC Warford, Ruckstell, and the high speed rear end. Those, make driving a pleasure. My top speed has been 36 mph. That's because I'm a pussy. Getting out on a highway, with less traffic and stop lights, would make me feel better about driving that 2700 lb. truck. Yes, I have Bennet brakes on the rear.
Having that KC Warford, makes starting a dream since the warford has a true neutral. Slip it into neutral and there's no creep or drag on the starter.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Tue Nov 11, 2025 7:14 pm
Good news, I picked up a hood and stainless steel tank from a fellow in Vermont. The hood will require a bit of tin knocking to fit, and one minor hinge weld, but should prove satisfactory.
The tank... Is going to require me moving beaucoup detritus out of the way.
jsaylor
Last Name: Saylor
Post by jsaylor » Thu Nov 13, 2025 2:21 pm
I had a TT years ago with a 2:1 overdrive. It ran with the others Ts with ease. 35-40 mph all day long.
donofnebraska
First Name: Don
Last Name: Cook
* REQUIRED* Type and Year of Model Ts owned: 1912 1925
Post by donofnebraska » Sat Nov 15, 2025 1:11 am
If I may interrupt this thread, I have a TT question. My TT project is helping a friend value his 25 TT. Do any of you have a good feel for values or have a suggestion as to who in the hobby I might contact to give my friend a value range for it? He is 95 years old and is looking for a good home for his very nice truck. It is located in Nebraska.
Last Name: House
Post by George House » Sat Nov 15, 2025 7:08 am
Don,… There exists a number of “TT experts” on this Forum. I’d recommend you start a new thread here titled something akin to ‘Heres What We Have, Whatsit Worth’? Then describe the TT -With Pictures- and you’ll receive many ‘expert’ replies.
36mike
Last Name: Russell
* REQUIRED* Type and Year of Model Ts owned: 1926 Runabout, 1922 Pickup Express,
Post by 36mike » Sat Nov 15, 2025 12:38 pm
I really liked that hood with the advertising on it.
Mike
Post by TXGOAT2 » Sat Nov 15, 2025 1:25 pm
Due their size and other characteristics, TTs appeal to a smaller market than Ts. Beyond that, condition, body type, location, and modifications will determine how appealing it is and to how many. Some people just don't have room for one, and many others have to live with traffic density that is not conducive to running a TT. A stock TT in good condition has about half the speed and twice the stopping distance of a typical T, and about half the fuel economy. For some, insurance and license fees might be an issue. A full description of the vehicle with plenty of pictures and information is important. There is a wide variety of bodywork on TTs. There is no "book price" on them.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Tue Nov 18, 2025 9:56 pm
Courtesy of Varmint here on the forums, I now have a fuel sediment bulb! By my untrained and amateur eye, I suspect it'll clean up nicely.
My collection of reference material is slowly growing as well. Picked up an original 1927 owners manual off marketplace locally.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Tue Nov 18, 2025 9:57 pm
Mike
It's available to a new home if you're interested. I'm building the truck as a personal vehicle, rather than a "work" truck. So the old work clothes clashed.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Sun Nov 30, 2025 10:37 pm
Well, one step forward, two steps back, as such things go.
My original gas tank bands are too small for the stainless tank. I reckon I can splice a small band extension in easily enough..
On top of that, the new made gas cap from Langs is slightly oversized, and as of right now, I'm uncertain as to how best to measure and find the correct cap. Thoughts on this would be appreciated. Perhaps I ordered the wrong cap? Or the bung weldment is for a different model?
But on the plus side, new electrical components have arrived! Im particular, new (shiny) guts for the headlights, and new distributor cables. Going to paint the cable holders, and make a pair of anti chafing inserts to protect the new wires.
Also, as a minor score, found a set of pull-a-part champion Xs locally for a pretty reasonable price.
mtntee20
Last Name: Miller
Post by mtntee20 » Sun Nov 30, 2025 11:18 pm
I'm not sure exactly how your tank sits. If it is like mine, "standard", you might fabricate some riser blocks to go between the frame and tank strap ends. Use longer bolts as necessary.
Good Luck
Post by TXGOAT2 » Mon Dec 01, 2025 9:19 am
Does the stainless tank have metric threads? I'd guess your fitment problems are related to the tank, not the T parts.
Maineiac
First Name: Michael
Last Name: Whalley
Post by Maineiac » Mon Dec 01, 2025 11:23 am
The sediment bulb screws in just fine, so it's not likely a metric/ standard problem. Unless of course, there's a thread pitch that's close to interchangeable with the bulbs NPT threads.
Post by Allan » Mon Dec 01, 2025 5:19 pm
The in-line fuel filter can be ditched with a new stainless steel tank. They are notorious for restricting flow on gravity feed systems like the T. Yours even appears to be fitted backwards to my eye. Usually the fuel is fed into the canister and then through the paper filter, before heading to the carby.
