Splash Shields
Campbell Tellman
First Name: Campbell
Last Name: Tellman
* REQUIRED* Type and Year of Model Ts owned: 1916 Ford Touring
Splash Shields
Post by Campbell Tellman » Thu Nov 13, 2025 1:36 pm
Good Afternoon1
I am working on a '16 touring car. Frame off. I cannot find info on the reassembly. When I lifted the body off of the frame I found 1/4 inch rubber pads at the bolt sites. My main question is do the splash shields mount between the body and frame without the rubber pads?
Are the rubber pads on top of the frame or between the body and the splash shields?
Thanks,
Campbell Tellman II
Beaufort, NC
Last Name: Gregush
Re: Splash Shields
Post by Mark Gregush » Thu Nov 13, 2025 1:40 pm
Neater above or below. There were no pads used on T's. Someone may have added to level the body out so you might want to check the frame rails for sag. If you did want to add them, I would suggest on top of the running board aprons, so the body sits on them.
Re: Splash Shields
Post by Original Smith » Sun Nov 16, 2025 12:57 pm
It's really good to see someone calling splash shields by the proper name!
Re: Splash Shields
Post by TRDxB2 » Sun Nov 16, 2025 2:18 pm
From Ford Parts Manuals - no reference to "splash shields" or 3 or 4 dip pans :o
jiminbartow
Last Name: Patrick
Re: Splash Shields
Post by jiminbartow » Sun Nov 16, 2025 2:24 pm
While rubber washers at these points were not original, someone in the past probably installed rubber washers at each bolt hole to try and silence vibration noise wherever metal to metal contact occurs. The theory is sound but rubber washers would have a tendency to keep the fasteners from being tightened as much as necessary and eventually start to come loose. Not good.
