Tube Size Question
mortier
First Name: Philip
Last Name: Jamison
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Tube Size Question
Post by mortier » Sat Dec 06, 2025 6:51 pm
Will 30 X 3-1/2" tubes fit 30 X 3" tires? I ordered those two tire sizes for my 1915 T, but all four tubes they sent are marked "30 X 3-1/2."
Re: Tube Size Question
Post by Wayne Sheldon » Sat Dec 06, 2025 8:13 pm
In recent years, generally speaking, innertubes have been the same for both tire sizes. It does matter a little bit, if an innertube has been used in a 30 X 3 1/2 tire and been stretched just a bit. It is possible that a somewhat stretched (or otherwise ill-fitting tube) may be more prone to folding over inside the smaller X 3 tire and may result in a pinch leak. Most new innertubes will usually fit either tire size okay.
For many years, manufacturers did make two different sized innertubes for the two tire sizes. However, so many users crossed them over both directions and in most recent years the cheapskate manufacturers simply decided to make a single size tube for both tire sizes.
Post by TXGOAT2 » Sat Dec 06, 2025 8:27 pm
I'm seeing new tubes with 2 or 3 sizes marked on them. In my opinion, using these tubes in a casing of the smallest size listed on the tube would be best. Less stretch, and perhaps better pressure retention. Bean counters dream of one number to fit all applications.
Post by John kuehn » Sat Dec 06, 2025 8:42 pm
I’ve wondered why Ford didn’t use just I size wheels to begin with and use 30 x3 1/2.
Maybe Fords engineers thought using the smaller size was some sort of advantage for the Model T car. When the smaller size was made that meant the spokes, rims, tires, and tubes had to be made differently too.
That meant maybe a little different tooling and time to make the smaller size.
Anyway after a few years a one size fits all approach began to be used. And if owners who had older T’s had the smaller 30x3 size on their car I’ll bet the owners eventually went to a wrecking yard to get the 30X3 1/2” on their car. But I wasn’t Ford or a Ford engineer to design the Model T Ford.
So I have a question. Are the hubs, brake drums, and differential backing plates the same for all T’s? If they are all the same switching wouldn’t have been hard to do.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sat Dec 06, 2025 11:45 pm
For All T's the answer is No.
There are early smaller hubs, and later larger hubs that are interchangeable, sorta as in both inner and outer parts and with redrilling holes.
There are ball bearing hubs and tapered roller bearing hubs that I believe you could call interchangeable.
There are straight axle and tapered axle rear hubs that are not interchangeable.
There are wire wheel and wood wheel hubs that are not interchangeable
There are small drum brakes and rear drum brakes that are not interchangeable drums.
The majority of T's built they are generally interchangeable but you have to pay attention and pick and choose your parts and maybe change other parts also.
If you pay attention and pick and choose swapping wheels, hubs, they can easily be swapped around like was done since Henry was offering to "upgrade" customer cars to modernize them.
Dealers, Junk yards and customers have been swapping things around since day one giving us so many mixed up cars today.
Mostly interchangeable, but not completely universal ALL interchangeable.
I suspect Ford used 2 different sized wheels in the beginning since it was normal to do so back in the day.
The carriages preceding automobiles and even a lot of bicycles back then had 2 different sized wheels.
And if it is felt to not need spend the extra money on larger wheels and tires then don't spend it.
Economies of scale and simplification were just coming into consideration when the Model T started.
Efficient production was just starting to become a bigger deal than just making a good design that works, lasts, serviceable, and all that stuff.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sun Dec 07, 2025 6:49 am
Philip,
Some manufacturers make tubes that fit several size tires and mark the tube as such. Other manufacturers make one tube for a given size tire. Changing clincher tires is not something I want to do more than I need to, so I am not going to use the wrong tube and have to change it again anytime soon. They sent you the wrong tube, send it back.
Loftfield
First Name: Thomas
Last Name: Loftfield
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1912 Express Pick-up
Post by Loftfield » Sun Dec 07, 2025 7:19 am
Straight answer, yes, you can put 30x3.5 inch tubes into your 30x3 tires. The size difference is minimal.
Post by DanTreace » Sun Dec 07, 2025 9:24 am
IMO, don't think that can work to stuff a 23" dia flap and the smaller 23” tube in the 30x3 tire casing that is made to fit 24" clincher rim.
30 x 3 1/2 clincher tires and tubes and flaps go on the 23” rim.
Got these from Coker, right size 24” dia. 30x3 brass stem tube, and proper 24" flap to go into the 30x3 tire clincher 24" front rim.
Post by TXGOAT2 » Sun Dec 07, 2025 10:28 am
Somewhere in the period Ford literature there is a dissertation by Ford on why Ford used the two different size tires. Economy in weight and first cost were the plusses, as I recall. A narrower, lighter front tire will steer more easily and the reduced unsprung weight, and rotating weight, will enhance performance and ride. Ford emphatically stated that the tires specified for the T were fully adequate and that the T had more tire for the load carried than most other cars. I would think that having all 4 tires and rims the same would have saved Ford money.
Post by Original Smith » Sun Dec 07, 2025 4:54 pm
Dan, did you have any problems cutting off the rubber stem on those Hartfords? I haven't tried it yet. I see you have an incorrect bridge washer. I wonder why that company can't make them as original?
Post by Allan » Sun Dec 07, 2025 5:15 pm
The last set of Blockley tyres I fitted came with Michelin tubes. These were metric equivalents. They were much thicker than any others i have ever fitted, with the exception of two old red rubber Goodyears. They were also smaller in cross section, so should fit 3" tyres well. I have had no experience with "skinnies" on the front wheels though, but have fitted quite a few "fat" 4.40 x 23"' tyres. The tubes that fit those will certainly not fit well in a 30 x 3.5" tyre.
Post by Scott_Conger » Sun Dec 07, 2025 5:21 pm
"Wrong" bridge washers cost $12 each, new
Who here would pay $30 each for "Correct" washers?
I seriously doubt that there is a market for correct new washers given that authentic parts can be had for a couple bucks, but I would not consider tooling up and making dies for less than that, and it would have to be for a market that displayed a healthy demand. I don't make parts on speculation any more - got enough of those on the shelf already... :?
I'll just sit back and wait for pre-production orders to roll in and see if it leads to anything.
Post by Steve Jelf » Sun Dec 07, 2025 6:00 pm
$30 for a bridge washer is pretty scary. I'm glad I got into this game when you could still pick up tire hardware cheap at swap meets.
BillM
First Name: BILL
Last Name: MAULDIN
* REQUIRED* Type and Year of Model Ts owned: 1923 Coupe
Post by BillM » Sun Dec 07, 2025 6:01 pm
What are the correct bridge washers?
Post by speedytinc » Sun Dec 07, 2025 6:24 pm
See above Jelf pix.
Post by DanTreace » Sun Dec 07, 2025 9:29 pm
Of course the correct is the original type of combination ring and bridge washer. The ring preforms the pressure around the base of the stem to prevent leakage.
With modern new metal stem tubes, the stem is already vulcanized to the tube, so the ring is insignificant, the repro flat bridge washer does it's duty of keeping the stem from shifting, as the rim nut exerts the pressure.
Now if the owner wants to cut off a new rubber stem tube to place a metal stem, the combo ring and bridge washer is needed, and the correct "777" small size ring and bridge washer and associate hardware has to be located, as this size isn't made new.
The advantage of the new metal stem tubes is the "725" size dust caps and rim nuts will fit with ease.
INo. 777.jpeg (87.01 KiB) Viewed 3989 times
The "777" is the smaller stem, but most later cars used the "725".
777 and 725.jpeg (121 KiB) Viewed 3989 times
Post by Scott_Conger » Sun Dec 07, 2025 10:38 pm
Well, now...
$1.85 in 1920 is equal to $31.13 in todays gelt, so it looks like my estimated price is just a little bit LOW and a bargain, too boot - compared to the original!
Such a deal!
Thanks for that, Dan :D
Post by Allan » Sun Dec 07, 2025 11:08 pm
Note in Dan's first printed page....the tube is sandwiched between the flange on the valve stem and the bridge washer with its pressed in sealing ring. That drawing that keeps on being posted showing the FLAP also sandwiched between the flange and bridge washer is just that, somebody's inaccurate drawing.
With rubber stemmed tubes, there is no bridge washer and no stem nut to take a dust cap, because there is no need for them, just as there is no need for them on brass stems, some of which were thinner and never had thread anyway. If any stem is canted in use it indicates that the tyre is running under-inflated. Anchoring it with a stem nut to keep them upright Is not the amswer. Noticing a canted stem may well be a wake-up call that the tyre needs to be re-inflated.
mortier
First Name: Philip
Last Name: Jamison
Post by mortier » Mon Dec 08, 2025 8:51 am
My supplier (Blockley) tells me their 30x3 and 30x3.5 tubes are identical. I asked why the 30x3 tubes cost $5 more, and they replied that they will correct the pricing error on their site.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Mon Dec 08, 2025 12:50 pm
Well, now...
Such a deal!
Look again Scott. The $1.85 is per 100 washers. ;) But I guess that if you're tooled up, the material cost is negligible. 8-)
Keep crankin',
Eric
Post by TXGOAT2 » Mon Dec 08, 2025 1:19 pm
Hot Lunch, 5 Cents.... NO income tax, no "Social Security"...
Post by Scott_Conger » Mon Dec 08, 2025 1:29 pm
Ouch
reading comperhenshion...
YellowTRacer
First Name: Ed
Last Name: Archer
Board Member Since: 2009
Post by YellowTRacer » Mon Dec 08, 2025 6:13 pm
For the purest, I have a couple of sets of 777 stems complete with bridge washers and dust covers. The dust covers may need to be re nickel plated otherwise in good condition. Price is $150.00 per set plus shipping.
Ed aka #4
Post by Original Smith » Tue Dec 09, 2025 11:36 am
My point above is, if you are going to reproduce something, why not do it correctly, just like the original.
Post by TXGOAT2 » Tue Dec 09, 2025 12:26 pm
Expense, overhead, limited market.
Post by Steve Jelf » Tue Dec 09, 2025 12:27 pm
...if you are going to reproduce something, why not do it correctly, just like the original.
Correct in some cases. But in other cases, scale is prohibitive. The original was made in many thousands or millions, so each piece was relatively cheap. An identical piece made today in the dozens or hundreds may be so expensive that people won't buy it. Why isn't anybody selling new 26-27 gas tanks?
Post by Scott_Conger » Tue Dec 09, 2025 2:01 pm
Pre-order 2500 or more washers at $30 each and watch them appear.
Post by Original Smith » Wed Dec 10, 2025 10:54 am
Where can I buy 30X3 l/2 Michelin tubes and tires in the United States? The only good thing about Blockley tubes is the thickness of the rubber. The valve stems are out to lunch! I've been buying rubber stems tubes for years and cutting off the rubber stem and putting the correct old stock metal stems in. I contacted Blockley about making his tubes with just a hole in them for original valve stems, and he was not interested. This is what our hobby is coming to! There are good reproductions, and many more not so good!
Post by Scott_Conger » Wed Dec 10, 2025 11:07 am
Just what the world needs more of: an innertube that already come with a hole in it!
Because there's such a huge demand.
That was 5 minutes that the Blockley folks will never get back... :?
Post by Steve Jelf » Wed Dec 10, 2025 12:00 pm
Second-best has been good enough for me. Mister Thrifty saw the cost of Blockley tubes and compared it to the cost of much less expensive rubber stem tubes. When you do a comparison of costs, you will find why I chose the latter. Are Blockleys best? That's what I've read online. When I buy Hartford rubber stem tubes and install metal stems, have I found them adequate? Yes, I have.
Post by TXGOAT2 » Wed Dec 10, 2025 12:15 pm
Stem delete option?
Post by Allan » Wed Dec 10, 2025 3:49 pm
Michelin tubes come with the base of the stem vulcanised in place, The fitter has to screw in the valve stem.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Dec 10, 2025 6:17 pm
I have found the lowest price of tubes to work adequately in clincher tires. They pass the aftermarket requirements, which are proper fit and reliable function. The exact shape is of OEM is not necessarily required. Fit and function cannot be bypassed
I have never seen Blockley tubes. Hartfords are much thicker and heavier. Does this make it better? I don't know, but they are not low price. Never had a problem with the cheapies.
Art Mirtes
Post by TXGOAT2 » Wed Dec 10, 2025 6:39 pm
I'm not sure what brand tubes my T has, but I have to check the air pressure every week or so and they always lose about 3 to 5 psi in a week to ten days. All four behave exactly the same, as does the spare. I have other vehicles with tube- type tires and they do not lose significant pressure over several weeks to several months. I'm pretty sure the tubes, whatever they are, are at fault. The tires themselves have given very good service. It's possible that replacing the air with nitrogen gas would reduce the pressure loss and give more stable pressures over a wider range of running temperature. Such are the claims made. I'm going to replace the tires with new Firestones and whatever tubes Coker sells with them. If they behave the same way, I'll put nitrogen gas in them. Won't hurt; might help. I have a '37 Packard with a year-old set of Firestone tires and whatever tubes Coker sells with them, and they hold a pressure setting for months on end. The previous tires on the Packard were put on in the early 1980s,and they also held a set pressure for months on end.
Post by Allan » Thu Dec 11, 2025 3:02 am
Larry, Coker lists Michelin tubes. The metric size 760 x 90 is the equivalent to 30 x 3.5". For wooden wheels the screw-in valve stem is part no R2030.
You will be pleased with how thick they are.
Post by Allan » Thu Dec 11, 2025 3:12 am
Pat, if they lose that much pressure in a week or two, they are not fit for purpose. The purpose of a tube is to hold air! The Michelin set I fitted about 10 months ago were aired up to 60 PSI. When I recently checked them and re-inflated them to move the vehicle, all five read 45PSI. That's 15PSI loss over some 44 weeks, or about 1 lb in 3 weeks. Anybody should be able to live with that.
Post by TXGOAT2 » Thu Dec 11, 2025 10:32 am
I've had the car for 4 1/2 years, and the pressure loss is very consistent. I've tried adding metal stem caps with gaskets. Made no difference. I'd put Slime or a similar sealant in the tubes, but they have balance beads in them, and I don't think balance beads and anti-leak goop are compatible.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Thu Dec 11, 2025 2:04 pm
Nitrogen is slightly lighter than air. Consequently, nitrogen is not going to reduce the pressure loss compared to air.
Art Mirtes
Post by TXGOAT2 » Thu Dec 11, 2025 2:49 pm
A credible source asserts that inflating with nitrogen will reduce pressure loss by 40 % and keep tire pressure more stable across a range of temperatures. That assumes a tire with no leaks and filled with pure nitrogen gas. Search: "Tire Nitrogen".
Post by TXGOAT2 » Thu Dec 11, 2025 2:50 pm
Nitrogen inflation might reduce yellowing of white tires. (?)
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Fri Dec 12, 2025 10:29 am
As an aside, slightly related, we filled a 4-man life raft with helium in the 70's to lighten it for a 2-man 100-mile race down the Missouri river. The smaller atom size leaked through the rubber much faster than atmospheric air. We had to air up to stiffen the raft numerous times during the race. We still got 15th place, in the money, out of 200+ rafts. :lol:
Post by TXGOAT2 » Fri Dec 12, 2025 10:38 am
Do some reading on nitrogen in tires. There are advantages. No Miracles. What would be the weight difference between helium at a given pressure and (dry) air at a given pressure? A few ounces?
Post by Original Smith » Sat Dec 13, 2025 1:09 pm
I posted this ages ago, so perhaps some have forgotten! An 888 valve stem easily replaces the 777, being 1/4" shorter. Same everything else. It may decrease the weight slightly. I'm using them in all of my cars.
Post by Scott_Conger » Sat Dec 13, 2025 1:39 pm
Art
Nitrogen molecule is larger than oxygen, thus, removing the smaller oxygen component and substituting more of the larger nitrogen gives a gas fill which takes longer to pass through the naturally permeable rubber matrix or past the valve. Science and empirical evidence points to this being true result.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sat Dec 13, 2025 4:28 pm
. . . What would be the weight difference between helium at a given pressure and (dry) air at a given pressure?
If you’re running a Flubber conversion, helium makes the steering “lighter”. But be careful banking on hairpin turns !
Get a horse !
Post by TXGOAT2 » Sat Dec 13, 2025 5:25 pm
The gentleman with the speedster pictured in the Up Up & Away thread was an early adopter of Flubber. He managed the control issues by adding a vertical stabilizer/rudder and stub wings. His innovative, pedal-operated propeller limited forward speed when airborne, but with a good tailwind and a tight fan belt, he could reach ground speeds of up to 50 MPH under favorable conditions.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sat Dec 13, 2025 9:17 pm
. . . the speedster pictured in the Up Up & Away thread was an early adopter of Flubber. He managed the control issues by adding a vertical stabilizer/rudder and stub wings . . .
An excellent solution. Thanks for an astute observation, Pat.
:lol:
Get a horse !
